Question about Ovens
No volage at element posts.
Bake element fried. Replaced, but now no voltage. Traced wires back to control panel and checked. No voltage at posts on switch or thermostat that goes to bake element. Checked ''Broil'' post and when slector is on ''Bake'' we have 120V and when on ''Broil'' have 240V??? Are both bad? Called and was told that the selector switch is discontinued. Do not want to through good money after bad. Amana ART 6100WW electric Range Mg P1142685NWW
Thanks in advance. Tom
    President:
  • Ovens Master
  • 1,922 Answers
Your missing one 120volt leg,check your fuse/breaker panel then again at input terminals at unit and make sure you have a good neutral connection
Posted on Jul 29, 2009
Why doesn't the oven work?
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 11, 2015 | Ovens
My range ,GLES388DSA, lower oven element does not turn on.
THINGS TO CHECK:
the broil element
The bake element
Mar 15, 2015 | Ovens
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
Apr 17, 2014 | Frigidaire Ovens
Oven not getting hot
THINGS TO CHECK:
the broil element
The bake element
Apr 06, 2014 | Frigidaire Ovens
Kenmore md3 both elements stopped working at same time
the broil element
The bake element
Mar 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven element is sparking
you have a short and need to check it ASAP SHOULD BE ABLE TO VISUALLY INSPECT IT
the broil element
The bake element
Mar 12, 2014 | Frigidaire FGB24S5A Gas Single Oven
Oven element
The bake element
THINGS TO CHECK:
the broil element
Feb 15, 2014 | Frigidaire Ovens
Replaced oven element still not heating up
The bake element
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
Feb 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't heat up, display flashes bake
THINGS TO CHECK:
the broil element
The bake element
Feb 12, 2014 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire elements oven will not ignite
the broil element
The bake element
Feb 05, 2014 | Frigidaire Ovens
Ovens Logo
73 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
