Home | Black & Decker | TRO360 Toast-R-Oven Toaster Oven with Con... | Button to toast won...
Black & Decker TRO360 Toast-R-Oven Toaster Oven with Convection Cooking
Problem for Black & Decker TRO360 Toast-R-Oven Toaster Oven with...
Button to toast won't latch
By tonykshao on Jun 19, 2009
The button I push to toast ( like a rocker switch ) won't latch when I toast, need to hold the switch to toast. This is a model TRO-360-TY5.
I took apart the toaster and there seem to be a magnet that holds the switch until the time is up. magnet is attached to a small logic card.
Please help me determine the part I need to fix this problem. Thanks.
Best Solution
posted on Jun 21, 2009
Helpful)
cactus bob
Rank: Guru
Rating: 93%, 277 votes
THE BOARD IS BAD .the problem is b&d will not sell it to you . i had one that i DID FIX , there was a problem in the power supply on the board , i checked out the parts i needed there where 2 diodes , and an scr transistor i found bad . ordered them (with shipping 28.00 ) got them and installed . and the first power up POP the ic timer blew apart and damaged the two diodes . cost of the ic another 25.00 plus the other parts. so i now have around 60.00 in parts and 4 hours labor in to my great working 7 year old toaster oven ( that i only paid 25.00 for in the first place ) so unless your like me and never give up ,NO MATTER WHAT ! its time for a new toaster oven ......... if this answer helped please rate a 3 or 4 stars this high rateing will help keep me in the paid answer department , thank you
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Black & Decker TRO360
Questions and Unsolved Problems for Black & Decker TRO360
Do you recommend Black & Decker TRO360 Toast-R-Oven Toaster Oven with Convection Cooking?
Answer
Answer
I have the same problem on TRO350 and this is my third Black and Decker in 3 years! I have spend... (More)
Answer
Same as above. If you need any more details please let me know.
Answer
the off/on switch will stick in the "on" position.
Answer
the toaster switch on the black and decker toaster oven does not connect. the bake and broil part... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker TRO360...:
Top Toaster Oven Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Toaster Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
