Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
P-9, P-21, P-28 error code
I am getting a error code P-9, P-21, P-28
  • Konica Minolta Master
  • 6,168 Answers
P-9 Replace the black developer and drum unit.
P-28 Have tech clean the IDC sensor located under the transfer belt forward section (right side of the copier) the rear one towards back of the machine right side There are two clean both
Above two codes should then fix P-21 which is the fault that registration is not right. And Since the Black Image unit is the reference for the other three color in regards to Registration that is why P-9 and P-28 need fix first.
Posted on Dec 30, 2015
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Getting an error code of flashing 9 times then pause then flashing
Pride Mobility Products Corp Product Owners Manuals Specification Sheets Click on "Celebrity X"
9-flash usually indicates a blown controller. The larger pride scooters are known for blowing controllers and having melt-downs when they are pushed or towed too fast. EVEN WITH THE KEY OFF the controller still monitors the safety systems. If the system detects a "roll-away" situation, the controllers turn on and go into dynamic braking mode in attempt to slow or stop the scooter. If the scooter is being towed or pushed and this happens, the scooter tries to stop the motion, overheats and burns up. Catastrophic failure and 9-flashes will result.
Best regards
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Code f9 appears display shows "locked'
Google Amana error code F 9. Looks like a door lock situation which sometimes occur after self cleaning.
Get that info on meaning of F 9 so more people can help you. Or there might be someone with his error code book at the ready.
Good luck.
Oct 20, 2013 | Amana ACS3350AS Gas Kitchen Range
Hi, I was printing a document yesterday on my BCJ-85 printer, at the end of my printing I noticed that I needed to cahnge the cartridge ( ink was completed gone) which I did. I did not do anything other...
Before doing anything check the number of catrige e. g, 21,28, 26. Use the same one which lastly work for your printer
if it ok then
The place at catrige from where the ink comes out touches the surface inside, check if ink is there. clean it perfectly witn iso profile it should work.
Mar 03, 2011 | Canon Office Equipment & Supplies
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox dc12 error code 9-378
9-378 Drum Cartridge count expired (40K)
Aug 12, 2008 | Xerox DocuColor 12 Printer
Error code 9-343
all 9-xxx codes are xerographic problems,such as toner,drum,developer or auto density.install or replace one or the other.
Jun 30, 2008 | Xerox DocuColor 12 Color Copier
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
110 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
