Question about Toshiba DVR670 Player
DVR670 stops playing - Toshiba DVR670 Player
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
DVDs recorded from VHS with Toshiba DVR670 will not play on any PC or DVD player
Possible that the format is not recognised or if a program needs to be installed into the PC for playback.
If the VHS was not compressed and then digitised , the format can be having errors and so is not playing. we need to cross check this out before we can confirm the error.
Please test with the recorded version on another PC and also try with another recorder.
Oct 05, 2011 | Toshiba DVR670 Player
I need to obtain an owners manual for a Toshiba DVR670/DVR670KU DVD/VHS Recorderwith built in Tuner
Hello larry strunk,
if you click on the website below, it will take you to a website where you can download the manual. Just scroll down and you will a owner's manual in a pdf format.
http://www.helpowl.com/manuals/Toshiba/DVR670/10589
Good luck,
Joe
Aug 26, 2011 | Toshiba Televison & Video
Can not get sound playing a vcr tape but can get sound playing a dvd please help
What connections are you using for the DVD and VCR output for both the video and audio?
If you are using a "digital" signal (such as optical audio/HDMI/etc) the VCR audio will not pass through these outputs. You will need to connect up the analog (red/white) RCA connectors on the back of your unit to hear the VCR audio
I hope this help, Magoo
Mar 06, 2011 | Toshiba DVR670 Player
Just purchased Toshiba DVR670 and hooked it up. Cannot get a setup menu to appear on the TV screen. All cords/connections appear to be working as the picture has improved and it runs beautifully through...
Did you put the t.v. on the correct input select.
We have one dvd that uses video 3 and another set that
uses video 5.....
AND.. there is a set up menu on the remote
hope this helps.....we just bought one of these and
used this site to get help with our volume. Great site for
help....so if my suggestions don't work, then maybe
someone else help will
Nov 16, 2010 | Toshiba DVR670 Player
What does E40 mean? Why did it appear after I failed to get a timed recording made? Nothing in the timed information was awry.
I have the same dang problem, same model. Now, on another board, a guy named Wade Terry said he found the solution--and he thanked the host and left without telling anyone what it was. Good work, Wade!
Mar 14, 2010 | Toshiba DVR670 Player
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
Toshiba DVR670 Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
