Question about Psion Revo
Sony Vaio Loses Power, with both adapter AND Battery..
I have a sony vaio laptop, vgn-a600p. When we have a power outage, the battery and laptop loses all power. I have learned to unplug the laptop at night. However I forgot to the other night, and we had a short power outage. This is the second time for this problem. What happens is the whole computer loses power, even though there is power to the computer, have checked with an electrical thingy to make sure there is power to the laptop. I can't boot up the laptop period, with or without the battery, even after letting it "die" completely and trying to recharge the battery or coming up on just the adapter without the battery. The last time this happened, I was told I had to recycle the power?? Can you help me with this? Thanks.
0 characters
1 Points
My Sony P1i just went dead one day. it won't power up. Battery is fine. when u plug power the light glows and steady. repair shop says software needs reload, is there i can do myself, itried firmware...
My P1i appears completly dead after running Update Service. I've tried removing the battery, fully charging the battery etc. When i run Update Service again it just says my phone is up-to-date.
any suggestions?
Update only says "No new software is available for your phone. Your phone already has the latest available software installed."
Then gives the option to Exit only
Sep 05, 2010 | Sony Ericsson P1i
No power and a red light flashes
firstly check with the adapter if its working fine ( connet the adapter to the phone and check if the color of the ligt changes and also check if its able to charge by observingf the battery meter on the phone)
try charging using the a USB cable .
Check if the battery is discharging .
check for damages.
Apr 01, 2010 | Sony Ericsson XPERIA X1 Smartphone
Cannot power on the phone (z610)
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Nov 26, 2009 | Sony Ericsson Z610i Luster Black Phone
My battery is for some reason losing its power extremely fast!! Also when charging the phone and im on it, the battery still loses power, please help!
Remove the battery and wait for a minut. Now put the battery back in and try charging until its full.
Jul 16, 2009 | HTC G1
Sony ericssion p1i screen touch problem (not working touch screen)
Try removing the battery and pushing power button to discharge capacitance.
Check to make sure phone powers up and battery is good.
Purchase new touch screen.
Jun 27, 2009 | Sony Ericsson P1i
SanDisk 2GB micro SD memory stick isn't working in my laptop. I use a Sony Vaio with Vista, it has a digital camera memory stick slot, and pc adaptor slot for micro SDs. I slipped in my SanDisk memory...
Fixed it. All I needed to do was update the software drivers on my laptop. I have a sony vaio, so I looked up the software drivers they had online and downloaded them. After I installed them it worked flawlessly.
Jul 27, 2008 | LG KU990 Viewty
Deleted appointments
Problem was solved by HP folks! talkinglens!
Sep 12, 2007 | HP iPAQ HX4700 Pocket PC
Laptop / AC Adapter Problem
It maybe the problem of your laptop ac adapter,find a new universal laptop ac adapter to have a try.
Sep 14, 2005 | Fujitsu Siemens Loox 710 Pocket PC
Lost data
The device doesn't exactly work like a computer... It needs battery power to "remember" what the user does. When you remove the battery, you let it forget everything. It's like how your car stereo loses it's memory channels whenever they do battery related work. What I would HIGHLY suggest, is set Activesync to do a full backup EACH TIME the device connects (it's in Tools, Backup). THEN, when he loses the information, you do a full restore. That being said -- to do a "reboot" just push the reset button (small hole on bottom left side grip) with the stylus. If you want a more thorough reboot, it's safe to just take the battery out for a few seconds. I do this about once a day.
Sep 14, 2005 | HP iPAQ h6315/h6365 Pocket PC
Psion Revo Logo
193 people viewed this question
Top Psion PDAs Experts
Are you a Psion PDA Expert? Answer questions, earn points and help others
