Question about Kelvinator Dishwashers
Red light flickering on normal and Intensive - Kelvinator Dishwashers
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
How do I fix the intensive light flicker
you need to go through your wiring and check for any lose or bare wires if none are showing check the connection you might need to buy some electrical spray cleaner you can find it at auto zone or at really auto parts store
Nov 06, 2014 | Cars & Trucks
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Flickering red light
If this is a new unit, return it for an exchange. There is a problem with the output amp section. This should be under warranty, request an exchange rather than a repair.
Dan
Apr 10, 2008 | Audio Players & Recorders
Dishwashers Logo
12 people viewed this question
Top Kelvinator Dishwashers Experts
paul
paul
guitar zan
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
