Question about Epson Office Equipment & Supplies
I am getting my text cut off at the bottom what could be the problem
How to cut and paste
Move the mouse over text while you hold the left button. This will hightlight the text. After the text is highlighted right click the text. You will see multiple options such as cut, copy, paste, delete, etc. Select copy then go to a text box, and select paste to add the text.
Mar 03, 2015 | Computers & Internet
Cut and paste
Learning how to cut and paste can make your life on the computer much easier.
It saves time and is more accurate that retyping the information, particularly if you do it several times.
If you know how to highlight words on your computer, you can easily copy sections of text and paste them somewhere else.
Open a text document or an email that contains some type.
Click at the end of the block of text you located in Step 1 and drag with your mouse back to the beginning of the text to highlight the entire block of type you wish to copy.
Release the mouse. The selected area should be highlighted in a color, usually blue.
Right-click the mouse on the highlighted text and a drop-down menu appears.
Select "Cut" to copy the highlighted text and remove it from its original position.
Select "Copy" to copy the highlighted text and leave it in its original position.
Paste the text you copied.
Right-click in an editable text box and select "Paste" from the drop-down menu.
The text appears in its new location.
Alternatively, highlight the text and hold down the "Ctrl" key on your keyboard while you press the "X" key to cut the text or the "C" key to copy the text.
These keyboard shortcuts copy the text that is highlighted.
To paste it, click in a text box and use the "Ctrl" and "V" shortcut to paste.
Cut and Paste Techniques in Microsoft Word
http://www.homeandlearn.co.uk/mw/s3p2.html
Aug 25, 2013 | Computers & Internet
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
I now have Works, rather than Word on my computer. I also now have Hotmail rather than OutLook Express . . . which both are a heartache to me. One reason is that I used to be able to highlight and drag...
Highlighting is similar to cutting the portion of text to be pasted at an alternative area on the page displayed. Right clicking on the portion of text should generate the features list to cut text as copies to be later pasted onto another area. A situation where text cutting or copying is achievable though does to allow to paste on the same area has alternate capabilities of achieving success. Cut the email text required paste to an opened empty Microsoft word document to edit into desired specifications. Usually, the email has least capacity to allow several functions all at once. A cut text may be possible least allowing pasting since the program is still in enable mode until uncut is achieved. For example, cut the portion required to paste on clipboards or Microsoft word document. Once the text that was cut is pasted elsewhere, the function of cut has been disabled. Returning to the email area requiring pasting should be achievable with an open display area requesting a past feature. In which instance, the open Microsoft document contains the copy that would provide display to the email section requesting displays.
Jan 26, 2011 | Computers & Internet
How to cut and paste with a Dell
On PCs and virtually all windows programs the process is as follows:
1)Highlight the text to be copied/cut (put cursor at beginning and drag to end of text)
2) Left click to bring up the context menu
3) Select cut or copy (CUT removes the text, COPY leaves the text in place)
4) Place cursor at point where you want to insert text and left click again
5) select paste from the menu
Feb 03, 2009 | Dell Inspiron 8100 Notebook
Pasteing and how it works
If you mean pasting in relation to cut / copy & pasting
How it works
When you cut or copy something, for example text, it is saved into the clipboard. Then when you paste, the text that is in the clipboard gets pasted. You can paste that same text more than once, it stays in the clipboard until it is over written (by cutting ot copying something else) or you restart your PC.
How to use it
There is a couple of ways to cut / copy & paste
1. Use right clicking menu
you can select something, some text for example, then right click on it with your mouse and select Cut or Copy. To paste right click where you want the text to be pasted and select Paste
2. Use application's Edit drop down menu
you can select something, some text for example, then select the application's Edit drop down menu and select Cut or Copy. To paste click where you want the text to be pasted select the application's Edit drop down menu and select Paste
3. Use keyboard shortcuts
you can select something, some text for example, then press Ctrl + X to Cut or Ctrl + C to Copy. To paste click where you want the text to be pasted then press Ctrl + V to Paste
Hope this helps
-Magnon
May 10, 2008 | Computers & Internet
Text is too high on tilt display. Top of text and numbers are cut off.
sounds like the lcd screen has come unglued from the tilt window.
Aug 14, 2007 | NorStar T7316E Corded Phone
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
13 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
