Question about Grizzly G0453 15" Planer
Grizzly 15" planer shuts off durring use
Planer motor will shut of while planning a board
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Why does my delta portable thickness planer shut off after a few moments
Sounds like the thermistor is killing it. Probably the new brushes are generating too much heat. Did you put them in correctly, so the curved surface matches the armature sleeve?
Sep 17, 2014 | Delta 22-590 13-inch Portable Thickness...
Carrage won't hold thickness
Either it is not really locked in place, you have a loose nut on the other end of the adjuster or a bad bearing.
Sep 05, 2012 | Dewalt Planer (DW734)
Where do i find a rotocator
Hi and welcome to FixYa. I am Kelly.
I think your looking for a planer Rotacator but not sure. Is this what your looking for:
http://www.grizzly.com/products/G1738/images/
http://grizzly.com/products/Rotacator-For-Planers/G1738
This magnetic base dial caliper set will do the same job for much less: (Unless you have an aluminum saw table!)
http://www.grizzly.com/products/Magnetic-Base-Dial-Indicator-Caliper-Combo-pk-/H3022
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Garden
I have a Grizzley 20" surface planner but I don't
Hi tbamsolson,
You may download the manual, click the link below.
http://www.amazon.com/Grizzly-G5850Z-Professional-Planer-Single-Phase/dp/B0000DD4LR.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 25, 2011 | Grizzly G5850Z 20" Professional Planer w 5...
Is this a good planer?
I do not have that planer, but I live thirthy miles form a Grizzly Store in Williamsport, Pa.
I have many friends that will go no where else to get their tools for their shop...
Have never heard any complaints about any of the Grizzly products...
And yes I have a couple of friends that have that planer and they love it...
You should be well satisfied with that product!
heatman101
Feb 21, 2011 | Grizzly G5850Z 20" Professional Planer w 5...
I have a 15in Grizzly planner that undercuts the last 2in and have to pull the board out.
What you are talking about is called snipe, so common to planers they named it. If you measure the distance from the middle of your cutter head to the middle of the out-feed roller it will be the same as the snipe. It's a deeper cut at either of the board end and can be caused by incorrect feeding or misalignment of the in feed or out feed tables, or an unnecessarily high setting of the rollers recessed in the surface of the in-feed table. Some planers overcome this with table extensions and you can try to adjust your rollers to get rid of some of it but I haven't worked with any planers yet that didn't have some degree of snipe. The best way around it is to leave your stock over length to allow later trimming. If you have to pull the board out before it clears the out-feed roller, it may be worn, misaligned or not turning under power enough to pull the board all the way out of the cutter head area.
Nov 02, 2010 | Grizzly G0453 15" Planer
Wood will not feed through
I had this problem with a Grizzly that is chain-driven. One of the links broke. I replaced the link, and it's been fine ever since.
Apr 21, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Kenmore 62872 Electric Dryer
Grizzly G0453 15" Planer Logo
87 people viewed this question
Top Grizzly Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Grizzly Craft and Hobby Expert? Answer questions, earn points and help others
