When I turn tv on Toshiba appear on screen green light flashing once constantly
Main system control IC fault. When replacing, Main system control & its Memory IC; both should be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
SOURCE: LCD SCREEN WILL NOT TURN ON RED LIGHT FLASHING
what bank in p.a. can i open a checking account thats wont hold it against me if i owe another bank money?
SOURCE: when you turn on the tv the green power light
I had the same problem, it was fixed under an extended warrantee, caps on the power supply were bad, number 2074, they replaced it and another one on the same board.
Tv has been back and running fine for 2 months now, if you google Magnavox and blinking green power light you should be able to find a ton of hits on the same subject and many have repaired these tvs by themselves. Good luck, another solution is to order a new power supply, they run abut $150, if you can find one.
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
electrolitic capacitors 1000mf /10 v in pover unit
