Question about Reebok RL 725 Elliptical Trainer
Is this elliptical battery opperated?
Is it battery opporated?
Noisy when opporating
depends on what is cause of noise, if a fan, something in it, or could be a bearing worn
Aug 08, 2014 | Winix 50 Pint Dehumidifier WDH851
I want to replace the battery
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Replacing battery
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
Replacing the battery
You can use the link below to access a service manual download. Please see page 68 for the battery replacement procedure.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/C546i%20(version%203)(AJME,%20AMTE,ATRE).pdf
Aug 21, 2012 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
Reebok RL 725 Elliptical Trainer Logo
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
