Error code E5
I am getting error code E5 after AC running for 2 hours and then it starts giving hot air
jgwhomeequip
  • 1902 Answers
SOURCE: Plug gets red hot on A.C. after 1/2 hour running.
Local hardware store would have replacement plugs and yes that would help the situation out. But the problem may lie inside the actual outlet also. So you may want to investigate the problem alittle more unless you have already done so
Posted on May 21, 2009
SOURCE: blows hot air
My 2003 chevy suburban just started blowing hot air...it was working find , then i stopped to eat lunch, when I came out it started blowing hot air
Posted on Jul 01, 2009
Davaith
  • 56 Answers
SOURCE: 04 Suburban - AC runs then without notice driver side blows hot
You could be lacking Refrigerant in your A/C system. And or your Automatic Thermostatic Switch could be going bad. They do tend to wear Quickly. But in anycase, DO NOT try to recharge your system or have any no certified person touch your A/c system. This could Allwo moisture in to your system and destroy your compressor, and if it is overcharged then this could also cause a the cooling effeciency to drasticlly be cut in half. Also could damage the system. A compressor is very epensive. Only allow a 609 certified Tech or an ASE certified tech( dealer, or a/c shop) take a look at this.
This is an advanced problem please dont be overwhelmed by the information.
Posted on Jul 17, 2009
  • 496 Answers
SOURCE: AC ran for a couple of hours and started blowing
If it is icing over, it is low on freon. You might have a freon leak if the system is relatively new. It will take a licensed tech to check, fix leak and recharge.
Posted on Aug 25, 2009
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
My tcl split ac works for 5 min, then gives e5 code.
E5 s a communication error between the indoor and outdoor units. It is stated in the service manual that the wiring between the indoor and outdoor has probably separated at one end of the terminal block. Most of the time however, it is usually a failure of either the indoor or outdoor electronic boards. A multimeter and knowledge of how to read "communications voltages is required. The machine will continually assess itself electronically to make sure all components are working properly. If after a given amount of attempts to communicate with the outdoor unit the machine still cant "talk" to the other 1/2 , it will show an E5 error and shut itself down. You could try switching off the power at the isolator or meter box for at LEAST 15 minutes and then turn back on to see if it resets. This sometimes works. Do not, just switch off and switch straight back on again.
Mar 24, 2015 | Heating & Cooling
Why does the f5 display on my ac
Are you sure it is F5 and not E5, F5 would be a error code for a Frigidaire stove. now E5 would be a coil thermistor problem. Check and or replace the coil Thermister
Jun 29, 2014 | Frigidaire Heating & Cooling
E3 error code
e3 error code comes when room not getting cool after 3 hours ac working, pls close all doors and windows and if possible try to run ac in an empty room for 1 hour , then check for fault,
Oct 13, 2013 | Kenwood KW85 Air Conditioner
Error code E5 for model : MOB-10KDCHR
I have Boston Portable ac MOB-10KDCHR can not find a parts number for the drain cap and drain hole (rubber plug)
Apr 16, 2012 | Heating & Cooling
Unit shuts off, getting an E5 error. sounds like there is a lot of water inside. the customer service numbers for Windchaser are disconnected. PLEASE HELP!!!!
E5 is the fault code for Compressor overheat/malfunction it coulb be caused by the exhaust hose being too long or kinked, remove the exhaust hose and run the unit for an hour and see if your problem goes away, if so re-route the exhaust hose, if not you need to contact the manufacture
Jul 22, 2011 | Windchaser PACR10 Portable Air Conditioner
I have a Carrier Aircon. Model 42QH12-C and it is displaying error code 5. The aircon stays on for a while (anywhere between 10-60mins) and then turns off and displays E5. If I just press the 'on/off'...
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Dec 20, 2010 | Carrier 38CKC042 Air Conditioner
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
The E5 code is on, emptied the water tank; still on
AC Water Level Sensor for C475 and C360 Alen Portable Air Conditioners This is a replacement water level sensor for the C47store.alencorp.com/product-p/acwaterlevelsensor.htm. Check out this sight. Good luck
Aug 31, 2009 | Alen C475 Portable Air Conditioner
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
