Question about Icom IC-R8500 Base Scanner
IC-R8500 --DISPLAY IS FLASHING - Icom IC-R8500 Base Scanner
3 Suggested Answers
SOURCE: IC-R8500--Display is flashing continuously--no receive
First check the tape cables from Conv Unit and Rf unit to main unit.
Second find if the PLL ICs lock (MC145190) check voltage at pin 2 (LO) ~4,5Vdc in PLL Unit.
Third find If the (PQ30RV31) voltage ADJ in main works.
Posted on Apr 15, 2008
  • 120 Answers
SOURCE: power inverter on ic-r8500
wow thats a great radio, pack it up and send it to me.(just kidding)you might want to contact icom www.icomamerica.com and talk to their techs about this one. congratulations on having one fine radio, it is worth a quality repair,ive wanted to take one of those apart for years lol
Posted on Jan 02, 2009
ICOM RADIO IC-R8500 display blink freq and no audio signal
G'day,
You have an excellent radio my friend, and that means you require the best possible advice and info.
May I suggest you join yahoo group SPECIFIC to your radio Make/Model, the expert team there will need as much info as you can possibly can give so they can resolve your query, plus you can download manuals, diagrams and other great things for your radio.
I hope I have been of help to you.
Best regards,
Peter
Dec 12, 2012 | Icom IC-R8500 Receiver
NO audio signale
l would first check for audio from the external speaker connection which most have.
Dec 12, 2012 | Icom IC-R8500 Base Scanner
Nokia 2100 dead werno po
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 18, 2011 | Nokia 2100 Cellular Phone
My e63 is not turning on
1. Water damage
2. Fall down
Jun 15, 2011 | Cell Phones
My phone does not come on.
1. Water damage
2. Fall down
Jun 13, 2011 | Ericsson Cell Phones
I need frequiences for local police departments for my scanner valdosta ga 31601
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 04, 2010 | Icom IC-R8500 Base Scanner
Power inverter on ic-r8500
Jul 16, 2008 | Icom IC-R8500 Base Scanner
Nov 01, 2007 | Icom IC-R8500 Base Scanner
Audio problelms
Bad Solder Connections on The Main Board(Look for Ring Breaks)
Jun 10, 2007 | Icom IC-R8500 Base Scanner
Icom IC-R8500 Base Scanner Logo
138 people viewed this question
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
