Question about Cycling
Shimano stef28 how to assembly
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Assemble rear axle for a bycle
There are several different varieties of rear coaster brake hubs. The most common is a "Shimano". The easiest way to tell you how to reassemble is by referring you to either Utube, put "shimano coaster brake in search box or go to SheltonBrown.com. Again enter the shimano in the search.
Sep 18, 2014 | Coaster Brake Hub Kit Chrome Bicycle Bike
Rear axle assembly for triax 26inch crimson 21 speed with shamano equipt. Lt wt allow frame.model # 8507-44..made for dynacraft bsc inc. Just want a manual or an exploded view of the rear assembly.. thank...
I think what you want is a technical document for one of the many Shimano rear hubs.
Somewhere on the hub there should be a model number indicated. Go to the Shimano site and look around for it.
http://techdocs.shimano.com/techdocs/blevel.jsp
A professional Bike Shop would be able to help you out with service or repair and they would have the special tools you might need.
This link will take you to an excellent source of those tools and advice on how to service most anything on a bike.
http://www.parktool.com/blog/repair-help
Jan 12, 2011 | Cycling
Require assembly schematic for shimano dura ace shifter . left shifter lever failed, will not activate the front derailler, disassembled, found nothing broken, require advice regarding proper reassembly...
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Nov 14, 2009 | Shimano Dura Ace Front Derailleur Fd 7800
Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Oct 07, 2009 | Mountain Shimano Deore Bicycle...
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
