Question about Tascam CD-RW4U CD Recorder
L E D INTERMITTANT
RECORDER WORKS BUT FOR NO APPARENT REASON THE L E D READOUT COMES AND GOES .
I have a JBL home theater system that is about 8 years old. The sub woofer is independently powered with an ac line and now intermittently has static/white noise that comes and goes without any apparent...
Its probably electrical interference. You are better off replacing it, or borrowing a friends sub and hooking it up. Just to make sure it's not your reciever or any wiring.
Mar 14, 2011 | Audio Players & Recorders
My 2004 impala will start and then not start in no apparant reason. has done this more frequently lately
If you mean that it will not turn over all the time, it could be the starter solenoid or a bad electrical connection to the solenoid. This could be an intermittent problen until it goes altogether.
Apr 26, 2010 | 2004 Chevrolet Impala
Intermittent sound with cbl/sat. Sometimes sound
Your receiver is HDMI version 1.1,1.2 or 1.2a and just don't work with anything to be honest with you. It's an HDCP (copyright Issue) and 5v pass thru issue. and the list goes on. If you can, just run HDMI directly to the TV and optical or Digital Coaxial to your receiver for audio and all will be well again. If you need more help, just post a comment and I will gladly help some more
Jun 24, 2009 | Onkyo TX-SR875 Receiver
Refrigerator cools intermittently
replace the temp control ,,,, when it gets cold enought to cycle off the control wont let it come back on till something shakes it one way or another and the contacts makes to come back on / larry
Nov 29, 2008 | Refrigerators
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Over heating
In general I know of no reason per se to replace the thermostat and temp sensor because you replaced the radiator fan. If the temp gauge seems to be staying in the 1/3-2/3 of full scale, and there is no apparent engine control issues as the engine warms from cold to operating temperature then there is no obvious reason to replace those items. Other than fan motor failure is there any reason for you to believe these other parts are at fault?You can get a free fault code readout at an Autozone parts store which would highlight a temp sensor problem, but there is no fault code for the thermostat except maybe the one for engine running cold for too long a time after start up. You could also check the resistance of the temp sensor which should run around 10-14,000 ohms when cold and drop to 700-1,000 ohms when warmed up.
I don't know about the issue of replacing the thermostat because I don't know which engine you are working with. So let me know an
Jul 12, 2008 | 2002 Chrysler PT Cruiser
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
Tascam CD-RW4U CD Recorder Logo
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
