Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Frost in freezer drawer of lg french door refrigerator
22yooper
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
omaharox
  • 161 Answers
SOURCE: Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Posted on Jan 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: French door LG refrigerator with freezer on the
It might be something simple like the water faucet is not open all the way
LG FRENCH DOOR SERVICE MANUAL
Posted on May 21, 2010
I have lg french door refrigerator lfx21976st pull cold air but does not freeze in the freezer
Inspect back panel in the freezer section. Is it covered in frost?
Feb 01, 2015 | LG Refrigerators
LG Model lfx28978sw french door freezer door hard to open
its likely you have frost inside your tracks. best option for you is to defrost the freezer and let the ice inside the tracks thaw. then after the ice thaws the tracks should work better. If that dosen't help you may need new tracks for the freezer door
Aug 03, 2013 | LG LDC22720ST Stainless Steel Bottom...
LG French door refrigerator not cold, freezer is working OK.
open you freezer drawer, hold the light switch and see if the fans runs. if no fan you have either a bad control board or a bad fan motor. if you have a fan running check the back wall of the freezer for frost. if you have frost on the back wall you have a defrost problem. either way you may need to call for service. they can trouble shoot and replace the proper parts. if you use the process of elimination you will spend more in the end.
Apr 30, 2012 | LG Refrigerators
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
My freezer is producing a lot of ice. There is buildup on the side racks, making it difficult to push/pull the top drawer. There is also frost/ice build up on the back of freezer and bottom floor. I...
This always happens when you don't have 'FROST-FREE' refrigerator. Unplug the power cord or switch off the freezer for about one hour or more when lots of frost stacks (maybe weekly). Turn down the cold lavel to 2-3 instead of higher if there are not so many items in the freezer.
Nov 12, 2010 | LG LFD22860 Bottom Freezer French Door...
Freezer door doesn't close all the way on one side,
Make sure that there is nothing blocking the drawer on that side. If there is nothing there carefully inspect the drawer closure. There should be a little catch point when closing the drawer that makes it pull closed on it's own. If you are still having an issue you will want to replace the rail/slide assembly.
Jun 13, 2010 | LG LRFD25850 French Door Refrigerator
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
16 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
