Schematics allen heath xone db2 - Computers & Internet
4 Suggested Answers
  • 20 Answers
SOURCE: hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
Posted on Mar 10, 2010
  • 447 Answers
SOURCE: Hi I have two marantz amps witch cut in and out when run from
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Posted on Jun 04, 2010
  • 5603 Answers
SOURCE: I have an allen and
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Posted on Apr 11, 2011
I get a static buzzing noise out both speakers. it stops if I hold the plug cable or master out cables? turntable wires are grounded. help!
If this is stopping when you grab a connector then you have a bad solder on the connector. a short or break in the wire or a ground is bad.
Apr 07, 2016 | Allen & Heath Xone-22 2 Channel Dj Mixer
Where can i download download schematic of Allen And Heath Zed22fx ?
ZED 22FX Allen Heath
http://www.allen-heath.com/ahproducts/zed-22fx/#tab4
It appears that schematics are not freely shared.
I suggest that you use the links above to contact the company.
Sep 02, 2014 | Televison & Video
CHANNEL MONTIOR LIGHT WILL NOT STOP FLASHING
You've pressed the "solo" button by accident.
Jun 01, 2014 | Allen & Heath Xone:92 DJ Mixer
What is compatible mixer for technics sl-dq33
Take one with a balaced output and well if you want a nice sound then the allen & heath xone 23 http://www.allen-heath.com/ahproducts/xone-23/ is real nice and well build and they have also the c version with build in sound card, but that unit is a lot more expensive . But when it comes to soundquality, this the one. Numark makes perfect tables, especially the x serie , i have a x-5 for scratching but my denon has the best parts for it\'s price , with real good capacitors, only your choice will be the xone. and costs 300 euro, three times more expensive then the numark. and with build in soundcard 200 euro extra. For less you don\'t buy a lot and don\'t take the reloops, those are very old and upgraded four times. Greetings richard
Dec 29, 2013 | Technics Audio Players & Recorders
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
Only half the volume on the left channel of the mixer. Why? :(
Does the left meter do the same thing? If the meter matches the right one, I would suspect the volume potentiometer on the powered speaker. Try exercising the volume knob. There might be some oxidizing on the potentiometer.
Oct 25, 2017 | Allen & Heath Xone-22 2 Channel Dj Mixer
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Adding new equipment?
http://www.allen-heath.com/US/dl.asp?file=288
Apr 07, 2008 | Allen And Heath Xone 92 4-Channel DJ Mixer...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
