Question about Lenox Lido Tall Salt Shaker & Pepper Mill
Metal tops are corroded
Where can I buy replacement parts --they all corroded
Rotation of top side part
You need to replace the hinges for the LCD screen. If you are a DIY person, you can simply use metal door hinges and modify them. Alternatively you can buy replacement laptop screen hinges but be sure to buy hinges that are compatible with your laptop.
Apr 15, 2014 | Acer Aspire 4710Z Laptop Charger...
Amtrol them-x trol drum is leaking from top egde.I like to know how ti fix
Once these start to leak, usually the best solution is to replace the tank. It is corroding and will only corrode more with time. You could try epoxy for a short term fix, something like liquid metal.
Apr 18, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Loud noise during spin cycle. Bid from Sears was over $900.
buy a new machine,the spider gear is gone and the part is like 500 bucks,you used to much detergent and it eats the metal on the gear
Oct 16, 2010 | Kenmore HE2 Plus Front Load Washer
My blender seems to spin without the glass blender "jar" in place. Once the blender is put on top, the blade will not spin.
your blade assembly is corroded. take it off, and using a rag, grab the blades. using another rag, grab the other end (probably rubber) and turn CLOCKWISE - it's threaded reverse, so you have to turn to the right to loosen, not the left like usual. I had to clean out the rod that connects to the blades - it was all nasty and corroded. I cleaned it with my Dremel and regreased with a tube of grease I keep in the garage, cleaned all other parts with some Dawn, dried well, reassembled, and works almost like new. I'm guessing I ran it too long without pulsing the motor and the heat corroded the rod that's connected to the blades. OR you can buy a replacement blade unit for about $10 online on a blender parts site
Oct 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Code free player remote is kaputt
clean the metal parts where corrosion occurred by scraping it off and use rubbing alcohol to clean, should work or get universal remote.
Nov 06, 2008 | Televison & Video
Wand
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Jul 26, 2008 | Vacuums
Lenox Lido Tall Salt Shaker & Pepper Mill Logo
97 people viewed this question
Top Lenox Home Experts
Donni Steen
Tom Chichester
Are you a Lenox Home Expert? Answer questions, earn points and help others
