Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Will not turn on
Went to turn on the dishwasher and am getting no power light. Checked to see if it is getting voltage and it is. It has been broke for 5 days and will not turn on.
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jun 19, 2009
Lg LDF6920ST has no power. I went to turn on to run and nothing happens. Does not light up or anything. Was working fine this morning. Now nothing. Checked and made sure the breaker was not blown.
First check the small electrical box at and behind the kick plate below the door. Possible loose connections, usually wire nuts make the connection, turn them clockwise to tighten, check for melted wires at the connection. If all ok test there with a voltage meter at the white and black wires. Should be around 110. If nothing house issue, if power dishwasher power button or eoc issue. You can reset the eoc by disconnecting power for 5 min then reconnect.
Oct 30, 2013 | LG Dishwashers
Dishwasher won't start
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Checkhow to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Jul 06, 2012 | Maytag Dishwashers
My GE dishwasher, when i push the start button nothing happens.
1)check any fuse had gone in electronic board.
2)check the input voltage to pcb.(normal)
Jan 08, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
Bosch dishwasher SHE44CO2UC/22 no power or light, no response to the power on. We have checked fuse box and electrical supply. Is this an electrical panel problem? Is there a "fuse" to the dishwasher?
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Jun 26, 2009 | Bosch SHU5315UC Dishwasher
My dishwasher will not start
Hi!
Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Please see this picture of what the dishwasher switch looks like.
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Mar 13, 2009 | Frigidaire Dishwashers
Won't fill with water
Went through the diagnostic sequence on control board as per maintenance papers in machine, the problem corrected itself.
Mar 06, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Bosh dishwasher not starting
Since the power is fine, now to get to the issue. You will need to pull the front panel and see if there is power to the on/off switch. There should be the same as what is at the junction box of the incoming power. If there isn't the proper voltage there, then you have a broken wire. If the voltage is there, then check the voltage going over to the control with the on/off switch in the on position. If power there and not lighting up or starting. Then the control is bad.
Jan 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
361 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
