Question about Watches
How to set time on betsy johnson zerone bsquared watch
Johnmackspencer@gmail.com
Click the "Need help?" link on the Gmail sign-in page.
Aug 14, 2014 | Betsey Johnson Watches
How do you get back off betsey johnson watch to change battery
It is just pried off carefully with a thin pocket knife, or using the tool that pops it off. I would let a jeweler do it if I were you. You can buy a tool to remove the watch back on eBay.
Mar 18, 2013 | Geneva Betsey Johnson Silvertone Chain...
Does the Seiko SND641 have an alarm? The seller claims it does, but it's not mentioned in the owner's manual.
Hello BW Johnson,
I've researched your watch and it does have an alarm located at the 6:00 hour position on the sub-dial. The one problem is that you will need to set it each day - even if you get up at the same time every morning.
Someone mentioned finding the setting in the manual. Perhaps, you might want to re-read it. From everything that I've been able to locate about the alarm, it doesn't seem to very easy to set or practical to use.
I hope that helps.
Best regards,
Sandy
Apr 11, 2011 | Seiko SND641 Watch for Men
I have just brought a Filigree bow clock necklace from dorothy perkins and i cant work out how to change the time on it
Found the pic. Cute...reminds me of Betsey Johnson.
There has to be a stem somewhere. See if the mechanisim part of watch snaps somehow out of the casing. I cant see the back of the watch in pic, Keep looking. Gotta be a stem there somewhere!! All else, take to a local jewelry store to have someone look at it too.
Best I can do for you hon!!
Jewel
Sep 18, 2010 | Watches
How do I remove links from my Betsey Johnson watch band
Oh dont you LOVE Betsey Johnson??? She has the cutest things!!!
Im sorry, but I am not familiar with each of her watches and fashion watches are all so different. Alot of fashion watches the links can NOT be removed.
My best advice is to take back to store for advice, or take to a QUALIFIED jeweler to have them look at it to see their opinion whether links can be removed.
Most stores if they can do it charge minimal for the work done.
Best regards!
Jewel
Sep 01, 2010 | Geneva Betsey Johnson Silvertone Chain...
I have a silver case Jos. Johnson key wind pocket watch made in Birmingham. Cas serial number 2508. Can yo tell me the year of manufacture?
If you go to Wikipedia and type in "
Joseph Johnson (watch maker)"
you will see there are a number of reference documents listed. The information you look for may be in one of these.
Jan 03, 2010 | Watches
Screw driver slots in watch band buff out. how do I remove link to make band smaller?
grab one with your teeth and the other with the johnson rod that came with it.
Jan 01, 2010 | Timex T42331 Watch for Men
I have an ESQ Aerodyne and the time set by the
this watch needs to be taken in as this is not proper time telling. has the johnson rod been used yet. if not, do so. if so have it taken in and checked with a caver device.
Jan 01, 2010 | ESQ 07301132 Aerodyne watch
How do i set the gmt on my Invicta Men's Pro Diver Swiss Quartz GMT Stainless Steel Watch
Set it only at night but not between 8 and 2. Use the johnson rod that came with it.
Dec 15, 2009 | Invicta Watches
Luminox timer bezel stuck
the reason the bezels get tight then stick is because after alot of wear and abuse it gets full of dirt, hair and really nasty junk you could not even imagine...take it to a reputable watch shop and ask them to take off the bezel and clean under it
Jun 26, 2008 | Watches
Watches Logo
42 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
