Question about Black & Decker Garden
Black and decker pressure washer wou,t start electic
4 Suggested Answers
picatudo
  • 239 Answers
SOURCE: NO PRESSURE FOR BLACK AND DECKER PW1400
the pump went bad
Posted on Dec 28, 2008
  • 7 Answers
SOURCE: i have a black & decker pressure washer model
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Posted on Sep 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Black and Decker PW1300 Type
Hi and welcome to FixYa, I am Kelly.
Not sure if anyone has responded to you but.... This is a symptom of the unloader / bypass valve sticking. The unloader bypass valve is located on the output side of the pump either under a brass cap or an extended stem with a knob on it for pressure adjustment.
Try this...
- Lay the unit down so that the water supply connection fitting is facing up. Leave the high pressure hose connected with wand. (Power to the unit)
  • First inspect the inlet screen for debris.
  • Next pour about 3 oz of regular automotive engine oil in the water supply fitting. Take your time... do momentary on / off cycles of the switch (bump the pump.... on / off) You are trying to get oil to the outlet fitting (No more than 1 second on off cycles)
  • Check for evidence of oil at outlet fitting
  • Leave it set overnight with oil in the unit. (Water supply and outlet fittings up.)
NEXT DAY.... add 2 oz more oil and connect water supply. (PURGE HOSE of ALL air before connecting)
  • Do not pull wand trigger yet
  • Cycle unit on and off about 10 times slowly... don't ruin the switch then let sit 10 mins.
  • Turn unit on without triggering and let run for about 2 minutes.
  • NEXT STEP be advised your going to shoot out OIL
  • Begin triggering the wand on 1 sec off 3 seconds for at least 2 minutes (your trying to get the unloader bypass spring / plunger and seals to start moving inside the pump high pressure area.)
  • If your wand has a soap application function make sure the wand is in the HIGH PRESSURE position. (Closed CCW)
This procedure does not always work but, I have revived about 70 % of the pressure washers I worked on by just doing these steps. If the procedure does not work... you will have to disassemble the unloader / bypass valve by pulling it out of the housing and then cleaning up the inside of the pump housing and wiping the seals clean. IMPORTANT STEP here: Before inserting the valve back into the pump housing you MUST lubricate it with #105 white grease. Housing and unloader / bypass valve parts. (white grease in small tubes at any automotive parts source.
Thanks for choosing FixYa,
Kelly
Posted on Feb 26, 2011
Black and decker pressure washer just stopped working
Electric pressure washers have a switch that cuts off the power when the pressure builds up after closing the trigger. In my case that is how I got my washer. The switch stuck in the open position thereby not letting the motor start back up. I took the covers off until I found the switch which had a stem sticking out that I could push back to operating position. I was able to drill an access hole in the cover so I could push to reset my switch because I didn't have a parts list to get a new switch. When you get the covers off you can check the switch with a meter to see if it is open and possibly reset it manually for a test to see if that is the problem. The switch should be replaceable. I hope this helps.
Apr 24, 2014 | Black and Decker USA Black & Decker...
Manual for black & decker elect scissor sz360
Cut and paste the following URL into your web browser>
http://servicenet.blackanddecker.com/Products/Detail/SZ360
You will see the pdf for thne manual on the top right hand side of the page.
Aug 06, 2011 | Black & Decker Kitchen Appliances - Others
I need to download a Black & Decker manual for a power washer- PW 1600
This link may provide the help you need, There is a phone # that you can call on this site:
www.ereplacementparts.com/black-and-decker-pw1600-1600-psi-pressure-washer-parts-c-4167_9499_9560.htm
I wasn't able to find it.They may know where to link you to to get a download of your manual. I wasn't able to find it.
Jim
Sep 23, 2010 | Garden
I have a Black & decker-pressure washer and the problem is the hose was broken. How can i fix or where i can buy a new one?
duck tape if it's completely dry and extremely tight. Mabey epoxy but that might not be strong enough. I would just get a new hose at blackanddecker . com or ebay
Black & Decker - Dewalt DP352 Pressure Washer 4000 Psi Hose
$71.99 new - TheHardwareCity.com
Jun 27, 2010 | Garden
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
Cord is rapidly "minced" up
PW1600 Black and Decker pressure washer - works for about 15 minutes steadily then quit - will not work again - power - test/reset is o.k. - Help!
Jul 09, 2009 | Black & Decker String Trimmer Cordless 12"...
Everything seems to be working but has no pressure. cratsman 1900 pressure washer
this could only mean that the motor shaft that drives the pump is stripped take it apart and drill a small hole through shaft and drive and thread the hole and insert a screw through
Apr 18, 2009 | Black & Decker Garden
Garden Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
