Question about Faema Emblema
Display reads Change SEL - Faema Emblema
What is a Wrench light indicator in my 2008 honda Civic
The wrench light indicator is a reminder that you are do for your next service(For example:oil change, air filter change, trans fluid change and so on) base on the miles on your car. A lot of people just get a oil change and have the light reset. If you read your car manual book it will tell you what service you need to do. Note: light come on every 3,000 miles and you can reset any time you want.
How to reset light:
1.with headlight off, turn the key on. Do not start the car.
2. On the left side of th dash below the heat vent there is a button that says "sel reset". push that button until you see "oil life" and a percent on the gauge display screen.
3.Now while on the oil life display, push and hold the "sel reset" button until screen start to flash. you might have to hold for 45sec.
4.when the screen start flashing, release button and hold it down again. might have to hold for about 45sec.
if you did it right the percent should go up to 100% and the wrench light should go out.
Dec 23, 2010 | Honda Civic Cars & Trucks
How do I set my clock in my 2005 CTS?
  1. Press the TUNE/SEL knob to enter the main menu
  2. Turn the TUNE/SEL knob until set clock appears on the display
  3. Press the TUNE/SEL knob to select set clock
  4. Turn the TUNE/SEL knob to adjust the time
  5. Press the TUNE/SEL knob to update the time.Time updated will appear on the display
Thank you for using Fixya and good luck.
Mar 16, 2010 | 2005 Cadillac CTS
Set the clock
Step by step included, change clock on JVC KD-s590 KTC- 4th Mar 2005 4:00 Setting the clock:
1 Press and hold SEL (Select) for more
than 2 seconds.
“CLOCK H”, “CLOCK M”, “SCM LINK” or
“LEVEL” appears on the display.
2 Set the hour.
3 Select “CLOCK H” if not shown on the
display.
4 Adjust the hour.
5 Set the minute.
6 Select “CLOCK M.”
7 Adjust the minute.
8 Press SEL (select) to finish the setting.
Dec 03, 2009 | JVC KD-S590 CD Player
Need to set clock on jvc kd-r200
Press and hold SEL to display the menu
Using the scan button (FWD/REV), select Clock H
Using the volume knob, select the valud
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Nov 01, 2009 | JVC KD-R200 Car CD/ MP3 Player
I just got a 06 Gsxr 1000 and the speedometer is stuck in kph. How do I get it back to mph?
press and hold the milometer button which resets yr mileage or push in and twist and make sure the ignition is on or it wont work bud
Aug 10, 2009 | 2006 Suzuki GSX-R 1000
How do you turn off the demo on the jvc car radio
Hello gusjandreau,
Press and hold the SEL button until the receiver enters the PSM mode (until the display changes). Use the left/right rocker switch until the display reads DEMO. Turn the volume knob until display reads DEMO OFF. Briefly press SEL to exit PSM mode.
Hope this helps.
Jul 22, 2009 | JVC Ks-U58 Input Adapter To Stereo Mini...
Help setting the time on a JVC KD240 Car Stero
Hello dmay006,
Are you releasing the SEL button after the receiver enters the PSM mode? As soon as the display changes, you should release the SEL button and then use the "up" button to scroll to the "item". Each time you press the "up" button, the display should change. When it reads "CLOCK HOUR", use the volume control to adjust the setting. Press the "up" button once again to advance to "CLOCK MIN" and adjust it with the volume control. Press SEL briefly once again to exit the PSM mode. Once in PSM mode, if no other button has been pressed within about 3-5 seconds, the receiver will automatically cancel the PSM mode.
If you are following this procedure and the receiver will not let you into the PSM mode or let you switch from item to item with the "up" "down" buttons, then it is most likely defective and requires service or replacement.
Hope this helps.
Jun 13, 2009 | JVC KD-G140 Car CD Player
Jvc kds641 changing time display
Here ya go,
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form.
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Demo wont go away
Hold the sel button until the display says demo. Release the sel button and wait for the display to read demo on. Turn the volume knob counter clockwise.
Apr 25, 2008 | JVC KD-G230 CD Player
Faema Emblema Logo
18 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
