Philips gogear sa1vbe
I need to by a battery for gogear sa1vbe, where i can do ? Thank you
2 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: BATTERY for 6gb mp3 player
i'm not sure what kind it uses but try Batteries plus. they have zillions of batteries. http://www.batteriesplus.com/
Posted on Sep 20, 2007
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
I am looking for a users guide/manual for a philips gogear mp3 video player that I purchased today - I want to print it out -please help
Which GoGear model?
http://www.p4c.philips.com/files/s/sa1ara08k_17/sa1ara08k_17_dfu_aen.pdf
For the SA1ARA
http://www.p4c.philips.com/files/s/sa1vbe04b_17/sa1vbe04b_17_qsg_aen.pdf
For the SA1VBE
For other models, try Google searching:
"gogear filetype:pdf"
Add the model number to the search string if you have it.
Apr 05, 2011 | Philips MP3 Player
My gogear is not working
  1. If your Philips GoGear is not turning on, the battery is more than likely shot. Open up the back of the unit by removing any screws you find, and then carefully removing the back. A guitar pick can help separate the back cover without scratching anything.
  2. Find the part number off of your battery and go to: http://www.partstore.com/OpenSearch/Model/Royal+Philips+Electronics/Philips.aspx
  3. Type in your part number and click Go.
  4. When your new battery comes in, install it in replace of the old one.
  5. When your GoGear is back together, plug it in to the charger and let it charge for about an hour before attempting to turn it back on.
  6. If you are still having problems with your device, you will need to contact Philips at: 1-888-744-5477, Monday - Saturday 9:00 AM - 9:00 PM EST, Sunday 9:00 AM - 6:00 PM EST Excluding Major Holidays
Jan 23, 2011 | Philips GoGear SA3245/37 Digital Media...
I'm not having software.so i'm unable to repair the mp3 player of philips..........gogear 2gb.pls assist me how to repair my mp3 machine....?
Hi!
Your problem posted under Philips GoGear HDD075/17 MP3 Player, so I am assuming it is the device you are trying to re pair.
The MP3 Player Firmware Upgrade 4.41d drivers is the one you need. This is compatible for the following models.... Philips HDD050/060/065/066/070/071/075/077
1. hdd070_17_fus_aen.zip
If you need more help just post back.
Please rate me if my answer helped you and leave also some testimonial
Thank you.
Nov 17, 2010 | Philips GoGear HDD075/17 MP3 Player
Charging battery
you might have a faulty charger or the battery just won't charge , if you can exchange it back at the store I would do that , but otherwise the charger would have to be tested and the battery , and if those are ok then something is wrong in the mp3 player
Oct 12, 2008 | Philips GoGear SA2825/37 MP3 Player
Frozen gogear philips mp 8gb
thank you for your concern: i fix it and the only way its to let the gogear run of battery and then you have to run the cd so you can download the songs from the itune library.
Jul 26, 2008 | Philips GoGear Flash MP3 Player
Philips HDD1630 MP3 Player about 2 years old, no excessive use, won't charge any more or be seen by computer. Only shows low battery on screen then dies. I am a little technically incline, can anyone tell...
You may have to change the battery, but try Reset, Repair, and Update (firmware upgrade) first. Also, there is an FAQ on the Philips website for the computer does not recognize device issue (but only follow it AFTER you have tried reset, repair, and update).
Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
After repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
Feb 05, 2008 | Philips HDD1630 MP3 Player
MP3 keeps deleting everything
Here is something that might help from tha mp3 doctor which i have gotton, thogth I still need the deivce manger:
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
-Tha Mp3 Doctor
Hope that helps and I just toke this from what I was told.
Jan 25, 2008 | Philips GoGear SA178 MP3 Player
75 people viewed this question
 Grubhead
Grubhead
