Question about Zanussi ZWF1430W Front Load Washer
Noise from zanussi washing machine drum - Zanussi ZWF1430W Front Load Washer
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
  • 54 Answers
SOURCE: Zanussi FJS 1197W washing machine main bearing
sorry you will need to remove drum
Posted on Feb 14, 2008
SOURCE: zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Posted on Apr 23, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
My 10 year old Zanussi front loading w/machine makes a lot of noise sometimes when spinning. Can this be fixed or is it time for a new machine?
Time for a new machine. Bearings are gone. It can be fixed but will be costly as it will need a new drum rear.
Feb 22, 2011 | Zanussi FJS1225W Front Load Washer
Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Loud banging in spin cycle zanussi aqua cycle
if you can get the front plate off you will probably notice that the drum stabilizer roller has either fallen off or is damaged. This part is replaceable and should be no more than 20 bucks.
Apr 27, 2009 | Zanussi F1045W Front Load Washer
Zanussi washing machine drum will not go round at all
Apr 08, 2008 | Zanussi ZWF1430W Front Load Washer
Excessiv drum movement back and forth
this noise is from the drum bearings and yes its a big and exspensive job to do complete strip down and will more then likely cost around £120-£160 to do if u like the washer and its in good condition then have it done because zanussi's and r good machines u can buy the rear of the drum with the bearing already in it but it still needs the drum taking out and then splitting from the front part of the tub but there again it will still cost u upto £100 anyway to do why this happens is mainly over filling the drum
Feb 24, 2008 | Zanussi ZWF1630 Front Load Washer
Noisy spin cycle
Hello your problem is the the drum.. To be more precise its the drum bearing.. theses wear out and can be replaced on the zanussi id suggest that you get an engineer out.. its about £100 to get it done
Dec 15, 2007 | Zanussi F1045W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
29 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
