Question about Compaq Computers & Internet
Checking media failed
When boot up, the screen goes into reading "checking media failed"
4 Suggested Answers
  • 7 Answers
SOURCE: hard drive
Hey this is not going to work. I have acer 5100 and I got the same mistake on the boot. I tried to restore bios setting to manufacture deafulls, nothing worked.
Posted on May 11, 2008
  • 10406 Answers
SOURCE: media read error check cable
Your computer tries to boot from various devices:
* CD-ROM
* disk-drive
* USB memory-stick
* 3.5" diskette
* network
in some order that has been configured (either at the factory, or by you, during BIOS SETUP).
So, if there is no media in the CD-ROM, no media in the diskette drive, no connected USB drive, then it will boot from either the network (if there is a network-cable that is connected to a "boot-server" system) or from the disk-drive.
So, is your disk-drive getting power?
Is the "data" cable between the motherboard and the disk-drive connected?
Is the disk-drive "dead" (not spinning) ?
Check your disk-drive.
You may need to purchase a new disk-drive, connect it, and reinstall Windows.
Posted on Apr 02, 2010
joelwilcox
  • 1274 Answers
SOURCE: pxe e61 media test fail check cable
what error message are you receiving on the blue screen? if it resets to fast start typing f8 at boot and in the advanced menu, toggle down to do not restart on system failure. write down the hex code (0x00XXXXX) and report back. What version of windows are you running? have you tried to press f2 or f1 or whatever key it is to enter setup on your laptop @ boot and disable network boot?
Posted on Jun 12, 2012
How do I get the computer to boot will not read hard drive
Check the connector to the HDD run a diagnostic on the HDD.
Jul 09, 2014 | Toshiba Satellite M45-S265 Notebook
My computerr was working fine last night I turned it on today and dell media home came up then it goes to a blue screen that reads a problem has been detected and windows has been shut down to prevent...
Driver or software update that was incompatible can cause this, try to boot to F8 and run a disk check.
Also failing ram can cause this, check the ram modules using Mem test
Dec 30, 2010 | Dell Inspiron 1525 Notebook
Black screen with info that pops up immediately upon booting up
Hi:
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Apr 23, 2010 | Toshiba Satellite X205-SLI1 Notebook
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
When i turn on my notebook it goes to gateway screen. then ate the bottom left it says f2 to bios menu. well any way, on the boot menu it say's media test failure and exiting pxe-mof. under that it says...
ur Hard disk is giving u problem either it is failed or going to failed jus buy a new hard disk whichever suits ur needs i mean , hitachi's are the best i think reliable and fast go and solve
Feb 19, 2009 | Gateway MT6840 Notebook
Restoring a gateway gt5028
Try with another media center copy & install . If you find the problem there will be another reason wherin your cd writer/ rom may not be reading the disc dueto which it fails to install...........hope this may help you
Dec 21, 2008 | Gateway GT5028 PC Desktop
Won't boot. Power light on, No Video Signal message
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Dec 12, 2008 | Gateway Media Center 610XL PC Desktop
Won't boot up
sounds like the hard drive is failing, if things are not backed up then get it to a professional without trying to start it again as more damage my result
Jun 21, 2008 | HP TouchSmart IQ770 PC Desktop
Computers & Internet Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
