Question about GE Refrigerators
Astak camera manual
Where can I located the defrost timer on model gsh25jftaww?
  • 6 Answers
This fridge doesn't have a mechanical defrost timer.
The main control board at the back is responsible for the defrost
cycle.
Posted on May 07, 2014
TheMobilian
  • 8220 Answers
SOURCE: ATTEMPTING TO LOCATE DEFROST TIMER. DO U KNOW
Up in the console with the light bulb and cold control is that there defrost timer. Number 12
Posted on Jan 01, 2011
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
Krazytech
  • 725 Answers
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: WHERE IS THE DEFROST TIMER LOCATED ?
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
Where is the location of the freezer defrost timer
The defrost timer is usually located in the top of the refrigerator compartment or in some older models its located in the base of the unit. Normally you will see a small 3/8" hole in front of the timer that is used to move the defrost timer manually with a regular (flat type) screwdriver.
Oct 08, 2014 | Refrigerators
What comes with a "astak cm918t night vision security camera"? How do I and what does it hook up to?
If there is a place for an antenna then it is wireless. You can use any computer monitor, doesn't have to be anything specially made for it. You will however need the wireless receiver and you will still need power to the camera. On top of that you will need a DVR for recording unless you have no intent of recording then you can hook it to the monitor with will take a converter to match the inputs properly.
Sep 02, 2014 | Astak Home Security
Manual for a ASTAK CM 818t night vision
Your request sent directly to Astak could yield the manual.
Jun 30, 2014 | Lorex Weatherproof Color Day/Night Camera...
How do I set up my Astak cm101 receiver to my Astak cm815t camera
please read your owner manual they contain a LOT
informatin about all questions.and proceed according
God bless you
Sep 24, 2012 | Cameras
Need users manual for ASTAK CM-909 wireless receiver
User Manual :-https://files.acrobat.com/a/preview/50207bee-6d42-4187-9978-a56e55f79a3b
Email: support@astak.com
Call: 1-866-368-8788
Business Hour:
Mon - Fri 9AM-6PM Pacific Standard Time (PST)
Sep 24, 2012 | Vision Astak CM-840J 2.4GHz Wireless...
Owners manual for 008-09-0115
Kindly type your model number followed by 'operation manual' in google search engine. You will find a number of websites providing free manual. Just download it and follow the instructions there.
Jul 10, 2012 | TruTech PVS2119 19 in. LCD Television
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
How do I obtain a manual for a GE refrig - model GSH25JFTAWW
Well you can please follow the below link to get your manual -
http://www.devicemanuals.com/guide/Refrigerator/GE/GE-GSH25JFTAWW-Side-by-Side-Refrigerator-Owner's-Manual-==TWprME1UWXk=.html
(Just copy and past the above link in your web browser, and follow the steps to download the manual)
Good Luck!!
Thanks
Mar 01, 2010 | GE GSS25JFM Side by Side Refrigerator
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
