Remote codes shinco rc-173dt
Sky remote not working
SOURCE: sky remote code for soyo onyx
I have this tv too. I just bought a remote control with a 'learn' function, (from a pound shop), You use the Tv's remote and copy the button functions onto the new remote, It works great, actually better than origional remote, also functions other equiptment too, sky, freeview, dvd, etc. Try that instead.
Posted on Sep 05, 2008
greenspan
  • 1734 Answers
SOURCE: SHINCO DVD - 100 English manual to operate the full function of DVD.
Go to http://chinamanuals.com - they are specialized on finding english manuals for chinese gadgets.
Posted on Feb 26, 2009
  • 403 Answers
SOURCE: I need a sky remote control code for a UMC LCD
Most remotes work the same when programming an item. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
welsh babe
SOURCE: REMOTE CODE FOR SKY REMOTE FOR BUSH A642F LCD
the code is 253
Posted on Apr 17, 2010
SOURCE: got a new toshiba rc
ponekad zablokira sve i dok ga ne ištekam iz struje i ponovo uštekam nemogu ništa
Posted on Jun 24, 2011
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
I use an older omega universal remote control but cant find the code anywhere to re programme it.my tv is a goodmans. i need it to use the av button as i cant get the sky on any other way! please help
shortie3030
I have provided a link with instructions on how to program your remote to your TV. The site also has remote codes. I hope this helps.
http://www.remotecentral.com/cgi-bin/mboard/rc-general/thread.cgi?1314
Ray Calo
DISH Network
Mar 04, 2011 | Universal Remote Control Dish Network...
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
My 26" TV/DVD combo remote seems Kaputt. Nothing works from power up on. Of course new batteries added. Seems very weak design (composite buttons direct on PCB). Any solution or source for replacement...
Try a universal remote, however I would advice you to try the buttons on the set to check if it works. It might just be a problem with the TV itself..........sodeep
Oct 09, 2009 | Mintek DTV-263 26 in. LCD Television
I need a sky remote control code for a UMC LCD Television, Model Ref: S19-4NG. I have a Rev 8 sky remote control. Sky tell me on their web site that I need to upgrade my RC. I have the latest version 8!!!!
Note:
Sep 23, 2009 | Televison & Video
Using An Onkyo Remote to control Sky+
Code that I have for sky + is: 01175. There are several other codes for other versions of sky boxes if you think you may need them but that should be the one.
Samsung has a huge code list: 10017, 10037, 10047, 10054, 10056, 10060, 10090, 10092, 10093, 10154, 10156, 10178, 10226, 10702, 10766, 10814, 11060, 11235. Unfortunatly you'll just have to try them one at a time until you find one that works. Hope this helps.
Jan 07, 2009 | Onkyo HT-S780 System
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Oct 18, 2008 | Televison & Video
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
if you find the manual could you please send me a copy I have the same problem I have a Shinco DVD 100 bought in cina but I do not understand cinese.
Thank you very much, if I found it I will send you, thi is my e-mail
villasts@gmail.com
my name is Rani
Feb 04, 2008 | Shinco DVD-833 DVD Player
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
