Question about Konica Minolta Office Equipment & Supplies
Error 2470 bizhub c5501 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Check all your connect on the printer control board had a new board installed???????????? Power off the machine get to the printer control board, check each connection pull it off check the board connector for a bent pin the reseat connector each and every one slow process
Posted on Dec 30, 2015
2 Suggested Answers
  • 30 Answers
SOURCE: Need to know if I can fix a Konica Minolta bizhub pro c5501 print control unit. The board has several resistors but how can I tell which ones need replaced?
I am certified on that model and we don't attempt to repair the boards. The issue is because it's color and people use them for counterfeiting, every resistor and load value must be precise or the machine will error out and become a huge paperweight. The other issue is the serial number loaded into the nvram board. It's a small board with a battery. You can't replace one board unless you install a new serial number into it which is very difficult and you need the instructions ect. I can safely say you won't have success replacing components. Sadly I would reccomend biting the bullet and calling in the tech to replace the board. It should come with a warranty so you won't have to replace it again.
Posted on Apr 03, 2015
"The board has several resistors..."
... and capacitors, and transistors, and chips, and....
I highly recommend you call an expert to repair the printer.
Apr 02, 2015 | Konica Minolta Office Equipment & Supplies
Forgot password for sphiwengcobo55@gmail.com
Click the "Need help?" link on the Gmail sign-in page.
Jan 21, 2014 | Compatible Konica Minolta Bizhub Pro C5501...
Printing 12 x 18 from tray 4 Every 2nd sheet jams.
MAKE SURE YOU SET THE THICKNESS SETTINGS AND OTHER SETTINGS ARE CORRECT, MAKE SURE IT IS 12 X 18, CLEAN THE FEED TIRES WITH WD 40 THEN RUBBING ALCOHOL, MAKE SURE ITS DRY BEFORE FEEDING PAPER
IF YOU HAVE A TRAY 5, ITS MORE RELIABLE
IF STILL PROBLEM HAVE YOUR TECK USE THESE PARTS
A03X565300 FEED AND TAKE UP ROLLERS
A03X565400 SEP ROLLER
56AA82012 BOTH CLUTCHES
AND TRY UNPLUGING TAKE UP ROLLER PICK UP SOLIENOID, WELL IT SHOULD WORK BETTER, AND MAKE SURE YOU DO THE BOTH SIDE ADJUSTMENT, WITH OUT SEEING EXACTLY WHAT THE COPIER IS DOING THIS IS MY BEST ANSWER
Aug 24, 2013 | Konica Minolta Bizhub C5500 C6500 C5501...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
115 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
