Question about Sony Ericsson CK15i TXT Pro Black
Update software sony reicsson
Headphone problem
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
Sony laptop with audio problems
go to your device manager and check the sound drivers are there if not right click on the icon and tell it to update driver software.
this might work.
Aug 10, 2014 | Sony VAIO Computers & Internet
Headphones
It could be that your headphone is defective.
Have you tried using different headphones? How about your speaker, does it work?
If none works,then I suggest that you update the driver (sound) in your computer. You can use RadarSync to scan your computer so that you will know which drivers are out-of-date. You can use the same software to update them all.
David
Jun 16, 2013 | Fujitsu Computers & Internet
No sound from my LG HD TV to my Harman Kardon receiver
Hi!.
i want to connect my akg t 912 headphone with Sony LCD. The audio output from setup box is attached with the Home theater and not directly to LCD TV. Suggest me the way to get the setup box audio output to AKG wireless headphone.
Jan 02, 2013 | Harman Kardon Audio Players & Recorders
I can't make or recieve phone calls on my xperia ray
Make sure your Audio Settings are correct. I am not sure if you can turn off your Built-In Speaker and Microphone. Also, make sure you have nothing plugged into the Headphone Jack.
Else, try updating your Phone Software to the latest version, available here:
http://www.sonyericsson.com/update/?lc=en&cc=gb
Select Xperia X10 from the list and download the software update.
You must plug your Xperia X10 into your PC using a USB cable to perform the update.
Oct 25, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Need a Operating Manual for a SONY ERICKSON Model 508A
Need a Operating Manual for sony reicsson w508a visit this link and download user guide in english http://www.sonyericsson.com/cws/support/mobilephones/learn-more/subject/userguide/1.589069?cc=cai&lc=en i hope it is heplful to you thanks
Jun 28, 2011 | Sony Ericsson Cell Phones
About my sony ericsson k750i sound
this generic problem for all sonyericsson mobile firmware update cause lot of problem ........your better press master reset in your mobile which will reset to factory settings
Jul 07, 2008 | Sony Ericsson K750i Cellular Phone
Killed Itself
Before you do anything else turn your phone OFF, take the batery out and leave it for around 10 Hours. Don't ask why, try it if it does'nt work >>>
Try downloading PC Suite from:
http://www.sonyericsson.com/cws/support/updateservice/updateservicesoftware/key.DownloadGeneral.SonyEricssonUpdateService_21839?cc=gb&lc=en
Then update the software on your phone.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Jan 18, 2008 | Sony Ericsson K750i Cellular Phone
Sony Ericsson CK15i TXT Pro Black Logo
14 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Dai Boyce
Dai Boyce
rajesh ettapurath
rajesh ettapurath
Unlockingcom
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
