Question about Craftsman Garden
Lawm mower back fires and kills when blade is engaged
My craftsman riding mower has sudden started to back fire upon starting and when I engage the blade it sputters and kills, making it hard to start at times
Had the same problem had to have someone look at it they said it was the fuel line and said it had no vaccum
Posted on Jun 22, 2010
    Problem Solver:
  • 8 Answers
Check your spark plug. Or maybe your choke is stuck
Posted on Jun 19, 2009
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
My craftsman 20 hp automatic lawn mower kills when i try to back up
It may have a safety lock on it causing you to not use the blades in reverse. My 07 craftsman has that safety feature.
Apr 13, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 18.5 42'' mower, blades won't engage
You deffinately have a loose wire or connection coming off that switch,youll have to investigate to find out where it is.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
281 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
