Question about Perspective Software MIDI Maestro MM4
Serial number maestro mm4 - Perspective Software MIDI Maestro MM4
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
Pleaz snd me the liecense key my serial number is357968006997941
Hello
Unfortunately we are not permitted to provide serial numbers , illegal download links or software to bypass the copyright protection of software in accordance with our terms and conditions and the DMCA copyright laws.
If you bought the product legally you should contact the manufacturer. The contact details should be on the side or back of the box or CD cover.
I hope you understand. Feel free to contact me if you have any questions.
Kind Regards
Andrea
Jul 29, 2010 | Sonic SmartSound Movie Maestro
Serial number of my Maestro 3100 worn off
hi rickricha397
your serial number is also located in the gps. turn it on, then go to the mail menu, then scroll to the right to the options tab, then to the system tab, then use the NEXT tab at the bottom, then product information..your serial number should be on the third line down.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Jun 29, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
License key for serial no 35153040940446
Hello
Kind Regards
Andrea
Apr 06, 2010 | Sonic SmartSound Movie Maestro
Give me exact the the serial number of my GPS magellan maestro 5310. because, this is the mark of the back 0764200585919. And I cannot able to enter.
your exact serial number can be found inside the unit in the product information section..on the main screen, tap the menu tab, then scroll ove to the options tab, the system tab, then scroll to the next page..there should be a product info and diagnostic tab..your serial number will be listed in the product tab.
good luck
bill
Jul 27, 2009 | Magellan Maestro 5310 Car GPS Receiver
Magellan3200 is not charging from car charger.screen says im plugging it into usb on comp. for me 2 follow the directions?? never had problem b4.can some1 plse help??
Try to dowload the latest firmware update for your 3200 register the unit in www.magellangps.com enter the serial number so that you can download the firmware and there will be instruction.
Jun 09, 2009 | Magellan Maestro 3200 GPS
Magellan maestro 4040
You can find the software applicable to your Maestro here:
http://www.magellangps.com/support/product.asp
Have fun!
Apr 26, 2009 | Magellan Maestro 4040 GPS Receiver
Maestro 4040 voice command unlock codes?
I think you are on the wrong track!
Why not call Magellan's Technical Support and raise the issue of misleading advertisement. If you argue it as well as I did you will end up with YOUR OWN VALID code based on the serial number of your unit FREE OF CHARGE.
How is it for the BEST SOLUTION?
Oct 09, 2008 | Magellan Maestro 4040 GPS Receiver
My magellan maestro 4040
call the magellan company tell them the model and serial numbers and any other info they will ship it to your home asap or go to the magellan website and register and you can get all the info on your model and anything else you may need
Dec 24, 2007 | Magellan Maestro 4040 GPS Receiver
Computers & Internet Logo
19 people viewed this question
Top Perspective Software Computers & Internet Experts
David Payne
David Payne
Are you a Perspective Software Computer and Internet Expert? Answer questions, earn points and help others
