Question about Olympus Stylus 7030 Digital Camera
Camera won't power on with fresh battery or cable
Why With a new battery, there seems to be no power on my canon EOS digital rebel xt?
Did you remove the USB cable? As long as there is an USB cable in the camera, you can't power it up.
Then you still have to check if the battery is still in good order. Batteries do have a limited time of life. And you only can be sure it is charged, when it works in another (same model) camera.
May 14, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
Camera won t turn on
What model Vivitar camera? What type(s) of batteries?
Jun 20, 2013 | Vivitar Cameras
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
My samsung pl120 won't turn on
You need to get fresh batteries in hope it will power on.
Mar 19, 2012 | Samsung PL120 Digital Camera
Camera won't connect to computer
Make sure the camera is on, and the selector is on the 'setup' spot. Batteries should be fresh, and a memory stick should be in the camera.
What does the manual say?
You can also have the computer search for recently attached hardware.
Mar 16, 2012 | Canon PowerShot SD780 IS / IXUS 100 IS...
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
I have a Kodak DC290 which has not been used for a while. Put new AA's in it but it won't turn on. Camera belonged to my husband, who recently passed away. Also can't find the manual. Can you...
If it sat a long time with old batteries, make sure they did not leak and corrode the contacts in the camera. Look at them and clean if necessary.
Jul 24, 2011 | Kodak DC290 Zoom Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
I can´t switch my camera on and i also can´t recharge the battry throw usb
The camera doesn't charge though the camera is on. It only charges when the camera is off. Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak V803 Digital Camera
Original Digital Rebel - Won' t power On
When I plug the USB cable in & have the camera on, the camera says busy & does not detect on my computer1.gif.
Dec 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Olympus Stylus 7030 Digital Camera Logo
37 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
