Watches Logo
K
Kent Hutson Posted on Apr 18, 2014
Replacing battery in a Claiborne CLM1011 watch
1helpful
Why did hands come off during watch battery replacement?
If the hands of your watch have come off after replacing the battery, it could be due to a few different issues. Here are some possible causes and solutions:
  1. Improper installation: If the hands were not properly aligned when the battery was replaced, it could cause them to come off when the watch is turned face-up. Make sure that the hands are properly aligned and securely fastened to the watch movement before reassembling the watch.
  2. Loose or damaged hands: If the hands were loose or damaged before the battery replacement, they may have come off when the watch was turned face-up. Check the hands for any damage or wear and if necessary, replace them with new hands.
  3. Damaged watch movement: If the watch movement was damaged during the battery replacement process, it could cause the hands to come off when the watch is turned face-up. Have the watch movement inspected by a professional watch repair technician.
  4. Incorrect battery size: If the incorrect battery size was used to replace the old battery, it could cause the hands to come off when the watch is turned face-up. Make sure you are using the correct battery size and type for your watch.
  5. Incorrectly set the hands: During the battery replacement, if the hands were moved or set incorrectly, it could cause them to come off when the watch is turned face-up. Double check that the hands are set to the correct time and position.
Oct 31, 2022 • The Watches
How do you get the back off for new batt
Replacing a Raymond Weil watch battery should be performed by an authorized Raymond Weil dealer. Replacing the battery on contemporary Raymond Weils takes some skill because the case is pressurized on some models or contains a rubber gasket to keep it water-tight. If you determine your Raymond Weil watch has a pressurized case back, don't attempt a battery replacement. Take it to an authorized dealer. The warranty on a recently purchased Raymond Weil watch will be voided if you perform a battery replacement yourself. Replacing the battery yourself on older Raymond Weils without a warranty is an acceptable risk.
I have a bulova 98m36 ladies watch and I need to know what size battery it takes
I advise you to take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
This is particularly true if you watch is sealed as replacing the back can be difficult.
1helpful
Can't figure out how to set day and date and remove back cover to replace battery
Replacing the battery is best left to a watch shop. It can be troublesome removing and replacing watch backs, particularly if they are sealed against water.
While you are in the shop, ask for advice on setting your watch.
Feb 13, 2010 • Watches
5helpful
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Field & Stream Mens Watch, F42GUBS
Take the watch to a jeweller. They should have all the batteries and seals and tools necessary for the job, and it rarely takes long or costs that much. you could probably manage yourself, but getting the seals especially is easiest through a jeweller anyway. Most likely reason for any watch to be not working is the battery, the next would be moisture inside - normally visible round the screen/face. always worth replacing the battery to see, unless the watch cost less than the battery, which it didn't. Hope this helps :)
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
