Question about Karcher Garden
Water leaking from lower end of kb3030b pressure washer plus loss of pressure
4 Suggested Answers
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
  • 174 Answers
SOURCE: I have been using a KB3030B electric pressure
The pump has a section with pistons that must have oil. The oil/piston housing is between the motor and the water portion of the pump. Some seals, somewhere are leaking. If you run it without oil it will destroy itself. You must get it fixed and I would do so before using it again.
Posted on Jun 11, 2009
dnewcombe1
  • 1564 Answers
SOURCE: pressure washer water leaking from gun
Depending on the manufacturer, you may purchase a rebuild kit for these very inexpensively. It's just a small pack of o-rings and maybe a spring or two. It would be a good weekend job, pretty simple to figure out, I've got faith in you. Thanks Dana
Posted on Aug 22, 2009
How do I solve my problem with my pressure washer not sending soap?
Pressure washers usually will not draw soap on high pressure setting. Switch wand or set wand to lower setting. Pin hole leak in soap line can also cause problem.
Jan 22, 2015 | Craftsman 2700 PSI Briggs Stratton...
My pressure Washer Pump Leaks water and does not pump normal?
If the pump is leaking water then you have a packing issue. this will cause a loss of pressure as well...check out here for parts Pressure washer parts catalog quick links Pressure Washers High Pressure... also check out here for specs and diagrams http://www.arnorthamerica.com/pumpbd.html
Aug 27, 2014 | Annovi Reverberi Garden
Washer over fills
Over filling us usually caused from loss of pressure in the water pressure hose. Check to see if it is pinched. The water pressure switch could also be bad. A rare thing could be a leaking or sticking water fill valve.
May 25, 2014 | Crosley Washing Machines
Mains cable on kb3030b
true!.. more info plz
Apr 21, 2014 | Karcher Garden
When using the sweep nozzle (yellow tip), the pressure starts and stops but the machine works fine when using the circluar nozzle(red)
usually when the power washer pressure stops the machine is running out of water. the sweep function uses a little more water than the round wash tip. Make sure there are no leaks in the supply hose and that the supply faucet is turned on all the way and has plenty of "flow". also make sure the water connection at the washer is not leaking. use a new rubber washer to make a good seal on the supply hose on both ends. if either end leaks or can **** air, just a little bit of air into the pressure washer will cause it to loose pressure.
Apr 20, 2011 | Briggs & Stratton Briggs Stratton 1800...
Loss of pressure in boiler, no obvious leaks, water pressure switch changed plus pressure release valve
Check that your make up water is on.
Make sure your fill valve is working but it sounds like it is not. Your min pressure should be 15 psig. on the boiler. Fill valve will maintain a15 psig on the boiler. Water and pressure does get out of the boiler when radiators are bleed. When fill valve is not working people will keep bleeding the radiators trying to get heat but only lowering the boiler pressure with no water make up.
Make sure your boiler is getting water and has pressure when running.
If it isn't...SHUT DOWN and have a professional look at it.
Pressure relief valve is factory set ta 30 psig and opens when pressure is above 30 psig. This is a safety valve.
Feb 17, 2011 | Heating & Cooling
Washer wont wash on large load but will wash on medium and small i want to kwow what is going wrong it want do nothing but fill up and leak on the flooor when on large load should i replace the washer
the water pressure hose connected to the load size switch and the lower outer tub has a hole in it,remove the control panel and replace this hose,it uses water height/pressure in the tub to trigger the switch to operate the machine and the hole must be at the upper end of this hose,so it leaks before the water gets high enough to trigger the switch on a large load
Sep 08, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Water pouring out from bottom of machine leading to loss of pressure
You will need to remove the main cover and see where the leak is coming from. Could well be either the water inlet or the main pump seals .
May 20, 2010 | Karcher PSI Electric Pressure Washer
I have been using a KB3030B electric pressure washer to clean patio and have notice oil leaking from bottom of casing. Don,t know where its coming from nor what to do
Jun 10, 2009 | Karcher K2.26 Electric Power Washer
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Garden Logo
32 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
