Question about Acer Computers & Internet
Packard bell s3270
How do I upgrade the RAM
  • Acer Master
  • 4,134 Answers
You can have a much as 8GB (2x4GB) RAM in the device. Here is a video that explains how to access the RAM. Good luck!
How to upgrade memory in Packard Bell OneTwo Computer
Posted on Nov 01, 2016
SOURCE: how do I instal two
As far as I know with that PC, there are 4 slots for RAM. Depending on what you have installed already some of those slots will be used.
Turn the PC off, unplug the power cable and turn case on its side. Remove the cover from the side and you should be able to see the Motherboard and the spare slots. Simply push the new RAM chips in to the available slots and click them into place.
Close the case, plug back in and boot up. You should see the PC memory checking then it'll boot. Check the RAM has been picked up by PC by right clicking on 'my computer' and going to properties. It should now show the amount of RAM you have installed.
Posted on Jun 27, 2008
  • 13433 Answers
SOURCE: installing a 2nd 256m ram
Installing more memory to a pc is very universal and is done the same way into all computers out there.
First unplug your pc
Open the side cover or remove the cover debending on your pc case.
Turn the pc sideways on the floor or table
and locate the memory slots near the cpu.
In this pc we have 3 memory modules installed
In this case I would have to remove one of the original memory modules first before installing a new one.
But in your computer you should have a extra slot open.
Simply insert the memory into the slot and turn the white switches on the sides to lock the memory in.
And you are done.
Posted on Jul 01, 2008
  • 39 Answers
SOURCE: Upgrade the existing graphics card. GEForce 4 MX440
Yes you can upgrade the card. For information regarding video card refer to website belwo
You can purchase teh AGP video card for the computer with higher memory.
Currently your video card is with 64Mb, try for 512MB or higher version. Do not go for PCI Express or PCI video card. The computer will support only AGP.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&AffiliateID=X3Th4gZi_iQ-O1wyxfEWrT9eDYy9TsHWNA
Posted on Apr 14, 2009
SOURCE: Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Posted on Jun 09, 2009
  • 4345 Answers
SOURCE: Upgrading RAM capacity
You actually cannot do this, It takes a 64 bit processor to run 4 gb.
Posted on Sep 25, 2009
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Packard-Bell EasyNote M5262 RAM upgrade
yes under the keyboard which you acces by taking off the bezel that should cover the hinges.
Mar 13, 2010 | Computers & Internet
I can't open my parcard bell netbook model zg5 and i want to upgrade 2gb ram. i want help pleaseeee!!!!
hi there
your parcard bell notebook memory only it only memory you have on phone or email parcard bell
they well help you
Dec 14, 2009 | Packard Bell Easy One Silver 2101 Notebook
Hi Guys I have a packard bell istart 1359, memory max is 2048mb and I currently have 512mb installed. I purchased 2 x 1gb ddr2 pc2-5300 -cl=5 -unbuffered -non ecc ddr2 - 667-1.8v -128 meg from crutial. I...
some systems require ECC it may be as simple as obtaining ECC Ram......u can try checking the memory that cam with it to see whether it is buffered and ECC if it is you will have to obtain same type of RAM
Apr 15, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Ram change on Packard Bell easyone 2120
Memory Upgrade Instructions
128 MB SDRAM on-board, max. 256 MB upgrade (384 MB total), PC-133
Remove the memory module according to these steps:
1. Turn off system power.
2. Remove the battery and disconnect the AC-adapter.
3. Open the top cover.
4. Press the locking latch downward to unlatch the Easy Start panel.
5. Then push it leftward and lift it up from the left side.
6. Slightly lift up the keyboard and disconnect the cable from the system board to free the keyboard.
7. Pull the retaining clips outwards (1) and remove the SO-DIMM module.
Keith Stoffer
Comptia A+ Certified Technician (20+ years)
Oct 30, 2008 | Packard Bell Easy One Silver 2120 Notebook
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
