Question about Sony Ericsson Live with Walkman WT19 Unlocked QuadBand GPS WiFi HSDPA Cellular Phone WT19i Black
Broken wifi antenna wt19i - Sony Ericsson Live with Walkman WT19 Unlocked QuadBand GPS WiFi HSDPA Cellular Phone WT19i Black
I unable to open my Sony Ericsson wt19i after switch on, it says setup guide stop unexpectedly stopped
SONY ERICSSON Live with Walkman WT19i How to Hard Reset my phone HardReset...
You will most likely need to follow the steps on the link above to complete a hard reset of the device. Be warned that your information will be erased and the phone will be returned to the factory default settings.
Sep 08, 2017 | Sony Ericsson Cell Phones
Sony vaio e series sve15113enw does not detecting wifi devices
There should be a button on the laptop that turns on and off the WIFI radio. You may want to be sure this is in the on position.
Jan 29, 2013 | Computers & Internet
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Internet and mms settings
You need to call your service provider and get them to resend you your settings. When you receive them via message just click save and it will automatically set up
Oct 15, 2012 | Sony Ericsson Live with Walkman WT19...
I cannot connect to the wifi
the problem may be;
1. your wifi antenna is broken
2. your wifi antenna driver software may be deleted
3. your phone software is damaged
go to this link www.htc.com you can register your compliant here if you have warranty. or you can locate the nearest service center of htc from this site and you can repair it there
Apr 05, 2010 | HTC PPC-6800 Smartphone
My wireless antenna seems to be broken and wont pick up a signal for the wifi...how can i fix this
update the BIOS and the drivers for the wifi.
If it doesnt work out the wireless card is the issue, needs to be replaced
Feb 06, 2010 | HP Compaq Presario F750US
GETTING INTERNAL ERROR 80410A0B WHEN TRYING TO ACCESS THE INTERNET. HOW DO I FIX IT?
this tends to be a common problem with dropped psp's . the reason that this happens when dropped it because the error has to do with the WIFI antenna . either its a very very low signal or your WIFI antenna inside your PSP is broken . you need to call Sony's customer care and get it repaired. i would not suggest doing it your self as it is very difficult to replace the antenna and it voids your PSP's warranty.
Dec 20, 2009 | Sony PlayStation Portable (PSP) Console
Broken Antenna wire
Oh, I get it now. That extra Sony one should work fine. Does this mean you got it working or are you still looking for a replacement? You can most likely find these on ebay by themselves or as part of a laptop wireless assembly.
Jul 01, 2008 | Zhone (6218-I2-200) Router
Sony Ericsson Live with Walkman WT19 Unlocked QuadBand GPS WiFi HSDPA Cellular Phone WT19i Black Logo
24 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Dai Boyce
Dai Boyce
rajesh ettapurath
rajesh ettapurath
Unlockingcom
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
