Question about Philips Irons
Gc4413 philips iron is leaking - Philips Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Philips 8320 leaks from soleplate
internal sealing ,rubber washers destroyed,,by expert professional
Dec 22, 2014 | Philips Irons
Philips iron keeps turnning off
We have the same problem here. The station only switches off after some time, but the iron itself keeps being switched on. So you manually have to switch on the station many times during ironing which is very annoying (for my wife). This was working before and we have tested here on different circuits already.
Sep 01, 2014 | Philips Gc8340/02 5 Bar Steam Generator,...
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
How to clean the water tank of philips steam generator
Nowadays there are various services for doing such work .You can hire them.There are also leak detection services who can help you in finding the leakages,repairing pipes ,removing mold and cleaning the tank.So it is better to hire them and check your pipes while cleaning.
http://www.allkarepropertydryingout.co.uk/luton/leak-detection-services-london.html
Jul 19, 2012 | Irons
Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 18, 2010 | Philips GC 8220 Iron
Irons Logo
49 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
