Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
DOOR ONLY LIFT A LITTLE BIT, THEM ENGINE STOPS
Was working normally for about a year and then suddenly started having problems oftenlly until now that is only lifting about 5 inches. When push buttom back again coes down bounce and stay open 3 inches and that is all.
Now I released de mechanism and use it manually.
Does this thing has a processor to control the process?
I check the alignment of the sensors and are ok.
Please help thanks Guillermo
Bought it at Sears
    President:
  • 3,197 Answers
First thing to check is the door springs. You most likely have a broken one. Look close it is sometimes hard to see that they are broken. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
Posted on Jun 19, 2009
HI I have honda 2004 accord. suddenly AC stopped
Maybe a fuse or relay.
http://www.autogenius.info/honda-accord-2004-fuse-box-diagram/
Jan 31, 2018 | 2004 Honda Accord
Kymco **** 125 (1998) Engine lost power then cut out, now won't start
Is this a gasoline powered motorcycle/scooter? If so and if you got off in dirt, the carburator may have dirt in it. Drain the gasoline, clean the jets in the carburator and try again. If its electric, sorry, can't help!
Aug 15, 2012 | Cars & Trucks
When driving the vehicle will die, if it sets for a little bit it will restart. This all started a year ago, when we turned on the air conditioning, before that it would run fine, but it seemed only w
If the compressor is failing, or there is a restriction in the ac system, the compressor could put a heavy load on the belt and the engine.
Normally the ac clutch would slip and not kill the engine, but anything is possible.
I t could be something else electrical too.
Jul 12, 2012 | 1999 Ford Explorer
Hi I have Lexus Rx300 year 1999. The problem is, some time when I start the engine, I noticed that the RPM meter shows low and the car little viberate and engine stops. But if in-between I push...
REPLACE SPARK PLUGS AND WIRES AND CLEAN FUEL INJECTORS. SOUND LIKE FUEL INJECTORS LEAKING FOULING OUT SPARK PLUGS WHEN YOU TURN OFF ENGINE.WHEN YOU START CAR UP NEXT MORNING CYLINDERS MISFIRING SO BAD FROM FOUL PLUGS ENOUGH SHAKE ENGINE.WHEN ENGINE RUNS FOR FEW MINUTES THAT WILL BURN OFF FOUL SPARK PLUGS UNTIL ENGINE RUN NORMAL.
Sep 06, 2011 | 2000 Lexus RX 300
I have a garage door opener (Chamberlain Lift Master Professional 1/2 HP) all the sudden it stops durring clossing & opening The garage door. no paticular spot. just on a random spot at ramdom times,...
Somewhere on the power head( motor ) is 2 knobs. The are to adjust up and down force. As the opener gets a little old you will need to turn these up occasionally! Turn to the right a 1/4 of a turn and try. I that doesn't work turn it up a little bit more. This should get you fixed up!
Jul 21, 2011 | Kitchen Ranges
I have sears opener #139.53989. Every once in a while I have a down problem. It goes down within an inch of the floor and reverses. Sometimes I can hold the wired remote button and it will go all the way...
If the main light flashes 10 times when the door reverses it is a sensor problem. Check them very closely. If they are just a little off one of them will be flickering but it is difficult to see. This can also cause the problem to be intermittent. Tweak them just a little.
It is normal for that light to blink randomly.
Jan 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Passenger window won't move
If it works a bit and stops and then will work a bit again and stop, odds are the motor is going and requires to be replaced.
You can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Pull back the weather seal and you'll be able to swap out the motor which is held on by a few bolts
Sep 04, 2009 | 2001 Dodge Grand Caravan
My error message says FC the oven door is locked I tried unplugging but that did not work . The cleaning cycle was stopped right after it was accidently started.
The self clean option usually can't be stopped once its started. you may have to let it finish its cycle (a few hours) and see what happens from there. It also sounds like you could have a bad door sensor switch.
Aug 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Dryer
I am a recently retired appliance engineer of 20 years this sounds like a door interlock problem, have you had it in bits, for some reason, it sounds like the wires have been reversed, it may be that the interlock has moved or been damaged, or has just gone faulty, check wires on the interlock are not shorting out, these can normally be sen after removing the lid, start with that and post if still having problem for reasons of safety the machine should not be left plugged in if children about work with safety, unplug when working on machine
Sep 09, 2007 | Malber TD700 Electric Dryer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
105 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
