Question about Bose Lifestyle 48 System
Remote does not work screen says other rooms are on cd,dvd
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - β€Ž58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - β€Ž18 votes - β€Ž$59.78 - β€ŽIn stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
My Go Video DV 2130 remote either no longer works or cannot be programmed to my Toshiba tv. There code listed in the instruction book for Toshiba does not work. Do I need a new remote or a different...
Have the remote tested--most shops will do this for free--point the remote at the tester and press a button and tester reacts.
This can also with most digital cameras be done---in a very dark room with camera on watch its display screen and point remote and press buttons--should see some tiny flash of light on the camera display screen---cheaper to fix the remote then get another--most of the Go Video units were made by Samsung.....
Nov 05, 2012 | GoVideo DV2130 DVD Player/VCR
How do i get my original remote control to work on a ewd2204 dvd/vhs combo after using a universal remote
If the remote that does not now work came with the unit--ie it is original and not a universal it should work.
Note that the remote can be tested--all shops use either a card test--it has a strip that reacts to the infrared signal the remote sends and lights that strip.
Some digital cameras in a dark room will react on their display screen in the same way when the remote is pointed at them and buttons on it pressed.
Idea is to find out if the remote is working or not....
Jun 13, 2012 | Televison & Video
RCA dvd player DRC6338T remote not working
The remote can be tested--shops use a card which when remote is pointed at and buttons pressed--a strip on the card lights up.
Many digital cameras in a dark or very dim room will react on the display screen in the same way--faint flash will be seen if remote is working.
If remote is tested and found to be good---try it very close to unit--you if no response at all and remote is good have a bad remote receiver in the unit(make sure the receiver lens is not blocked or dirty).
Apr 24, 2012 | RCA DRC6338 Portable DVD Player
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
I have a compack dvd/cd player I would like to have the televison screen blank when I play a c.d. rather than the compack name on my tv screen how do I change this on the remote for the dvd/cd player for...
You could just turn the TV off, since you're apparently not watching anything on it anyway.
Or you could possibly find a setup in the player regarding the screensaver. The function of a banner like that is to alert you that the TV is still turned on and something alive is working on the selected input. Otherwise, you might not notice it and leave the room for a long period with the TV still on. It's YOUR electrical bill.
Feb 08, 2010 | Audio Players & Recorders
My cd and dvd drives are not working
check the Dvd or CD room.. the connection, reading lens,
or the cd room board
.. you try another cd/dvd room to check
thanks
Jun 02, 2009 | Computers & Internet
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
I lost the remote to my APD-3955 portable DVD player
APD-3955 portable DVD vemote, dvd show room is avlible pleaase go to dvd show room.you will get soon. if internet you ask remote will come by post so many days after will came my suggens is your nerest shop only best.
thanks
Jan 03, 2008 | Radio Shack Accurian APD-3955
Dvd will not play
Hi there. If i understand correctly, you do have the official microsoft DVD dongle and remote ? If so, you might wanna see if the remote is defective. Do you have a camcorder at home ? There is a trick to see if a remote sends it's infrared signals. Put the camcorder on, in a dark room, and put the IR transmitter on the top of the remote in front of the camera. You'll see the IR remote transmitter blinking if you press some buttons. Human eyes can't see it, but the camera does! Try it with another remote that you're sure that works, you'll see. If the microsoft xbox remote doesn't do anything, check batteries, else it's proably defect. If you like to tinker a bit with things, you might wanna open it up to check if there's any cold solder point on it (a broken connection), but you need soldering skills to do so. Else, you'll need a new remote. Hope that helps ! cheebster.
Jul 03, 2007 | Microsoft Xbox Console
Bose Lifestyle 48 System Logo
27 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
