Question about Samsung DV5471A
Nothing turning on - Samsung DV5471A
Ignition will not turn
The key won't turn in the ignition switch? Or when the key is turned nothing happens?
May 31, 2016 | 2002 Cadillac Deville
I just received my Tomtom Go2535TM gps. There is no sound. What is wrong?
Take it back to the dealer for a replacement its faulty
Dec 24, 2014 | Tomtom GO GPS
When turn key nothing happens
check connection and wires at battery for damage or corrosion if good check for power to ignition switch if no power check for damaged or shorted wiring if good turn key and check if power going to relays or accessory's at fuse panel if no power switch may be bad
Apr 08, 2014 | 2002 Saturn S-Series
On a 1985 Camry, what is the button above the ignition key used for?
nothing (is nothing cant turn it at all or nothing can get ignition or crank positon)
it's the steering lock, latch?
new cars, dont have it , most older cars do.
if you dont push the button the key will not turn.
so did it turn, ? the key that is turn?
Jan 07, 2014 | Toyota Cars & Trucks
No power
replace the power supply board inside tv
Jan 30, 2013 | Emerson Televison & Video
Power button just flashes will no turn off AND nothing on the screen
On back of the computer is a on off switch for the power supply, or unplug the computer for one minute. Turn the switch back on, or plug the computer back in and try to turn it on.
Apr 20, 2009 | Computers & Internet
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
Samsung DV5471A Logo
24 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
