Question about GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
  • 410 Answers
Vic it probably correct about the fan. Remove the fan, wires, and bracket. Take the bearing end caps off, clean with q-tip and alcohol, then oil with clean 30 wt. oil, reassemble. No more howling for at least a year.
Posted on Jun 27, 2009
  • Scott Gee
    Scott Gee Oct 22, 2013
    FINALLY fixed this problem. It's NOT the fan motor. Tried that. It's NOT the control board. It's NOT how full you load the freezer or fridge. Mine is full. The problem is this: When they ship the units from the factory, there are two pieces of rubber trim that seal the left and right side of the fan box at the back of the freezer. During shipping, the trim slides down, exposing a 1" to 1/2" gap where air can get sucked in. This turns the fan box into a musical instrument. FIX: I simply put some electrical tape over the open spaces, and the howling stopped. It's been a week with no sound at all. Previously it howled all day, every day. The proper fix is to loosen the fan box and slide the trim back up into place, but putting tape over the gap will do the same thing and is easier. Enjoy your quiet kitchen! P.S. to GE: Please put some sealant on these gaskets before you ship them from the factory, so that they do not slide out of place during shipping. I'm sure they were silent when they left the factory, but you need to account for shipping. And inform your telephone staff of this fix.
    President:
  • 1,136 Answers
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 19, 2009
Popping noise
it's the aluminum defroster coils cooling after a defrost cycle.
a padded aluminum foil-covered mat installed behind the defrost heater in the back of the fridge is a fix at least for Samsung I know.
Jan 07, 2018 | Magic Chef CTB2125 Top Freezer...
Howling
Howling suggests something wrong!!!! Just kidding , of course. It does suggest that something is rubbing. Most noises are caused by vibration, same thing as the noise when my old bones rub together because the cartilege has worn away over the years. I suggest you find a food grade lubricant, hunt around at Lowe's or Home Depot for same. and if you have one, use a finger pressure squirt gun to squirt some of this stuff into the mechanisms that are inside your ice making unit. There are some small mechanisms in an ice maker that develop some pretty good forces especially to break up the ice. Unfortunately I am sure there may be some mechanisms that you can not get to very easily and you may have to take something apart.. Yeah, I know, involves emptying the fridge and all that bother...
Mar 28, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
713 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
