I have a set of tevion wireless headphones model no js-w002 and cant find instructions turn them on red light appears sometimes green appears and they work but dont come on everytime
2 Suggested Answers
SOURCE: i have a wireless headphones
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Posted on Dec 27, 2008
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
How do i pair HP500BT with device
After charging, turn on headset by pushing the power button until the charging led turns red and flashes. continue to hold the button until the light flashes red and green. Go to your phone or device bluetooth settings page and search for devices, it should show up as TPRO HP500BT. Select device and select to Pair with this device. The light should start flashing red really fast, then it should be paired!
Dec 28, 2013 | Technical Pro HP500BT Wireless Bluetooth...
The sound keeps breaking up the green light goes out and there is a terrible hissing sound
I know this is a bit late but i had the same issues with my unit. turns out if you listen with the source volume really low the headphones cant detect sound so they shut off. you fix this by simply adding more volume from the source and then just decrease volume on the actual headphones to obtain desired listening level and say goodbye to this issue.
Jan 17, 2011 | Sennheiser RS 110 Consumer Headphones
Headphone symbol though no headphones in so cant talk to people
It sounds like your device may be paired with a Bluetooth headset. Try turning off bluetooth connectivity and see if that fixes the issue.
Oct 25, 2009 | HTC Hero Smartphone
FM wireless headphone batteries not charging . Green light does not come on at all. Red light comes on sometimes.
you need to replcae the charging pin of your head phone, it is having loose connection............
Jun 20, 2009 | Philips (33-01-031) Headphones
Panasonic SC-PT760
Try pairing process.
It is in the main set Operating Instruction manual.
I cant really remember the whole process clearly but definitely in it.
Oct 18, 2008 | Panasonic Home Theater System System
I have Logitech wireless headphones for my Ipod, and I can't get them to work. When I press the on button on both pieces, it goes solid red and not blue.
Visit the Logitech support website and find the instructions to reset and pair them. Since yours is for an Ipod I'm assuming you have the older white/grey model and not the freepulse headphones. The procedure is not the same. From memory the procedure it to reset both (look for the small hole to insert a paperclip). Once both are reset begin with the transmitter. Hold the power button down for about 30 seconds until the light flashes red and blue. When it does do the same for the button of the headphone until it flashes red and blue. When both are flashing red and blue they should pair together and the lights should turn solid blue..
Oct 15, 2008 | Logitech FreePulse Wireless Consumer...
Connecting x rocker chair to ps3
I HAVE THE SOLUTION for all ps3 and ps3 slim gamers with the x rocker chair. it took my 2 long hours of frustration but i finally figured out how to make it work with ps3 slim. okay, forget about the red and white audio output plugs, those aren't needed. (my tv has no audio output jacks so i had to find a different solution) find the cable with the green headphone plugs on both sides. plug one end into the tx box and the other into the headphone jack on your tv. make sure your sound settings on your ps3 are set normally so that the sound is coming out of the tv. turn on the tx box, turn up the chair volume (and volume on the tv) and there you have it. enjoy!
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
87 people viewed this question
 Grubhead
Grubhead
