Question about Dyson DC33 Animal Bagless Upright Vacuum
Cover assembly How do I take off the hinge to replace the cover assembly for the fiter?
  • Official Brand Answer
  • 2,572 Answers
Hi Bobbie, it's Jack at Dyson.
For help with replacing the filter cover, it's probably best if you can contact our experts directly so we can provide further assistance.
At your earliest convenience, please give us a call when you have your DC33 to hand. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you.
Posted on May 06, 2014
There are usually two portions of the top lid to be removed to gain access to the motor compartment. Lift the top lid, squeeze the hinge to get the side into the frame of the hinge so it can release and allow them to come out. The same procedure should get the second lid removed. Now you should be at the second cover assembly, which is removed by releasing two, one on each side, snap clip tabs. They are located on the side of the 3rd cover, near the front corner. The corner needs to be lifted till the little tab snaps loose, then when both sides are loose this cover can be removed. Keep an eye out for screws that may need to be removed from time to time on some of the covers. They should be fairly self-evident when they're there. This should put you into the motor cavity so that you can lift the motor out , disconnect the wires and go check the motor.
Dec 12, 2013 | Kenmore Vacuums
How do you empty it?
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
Apr 27, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Disassembly of Miele red star?
First remove the lid by opening it and pulling straight up while using a screw driver to pry on the black hinges that go straight down into the unit. After that there are two silver screws on the black pedal assembly pull up and back to remove this assembly . Remove the HEPA filter. Remove the screws under the pedal assemble and pull straight up. What ever you do do not remove the cord winder assembly it wil spring and you will have to replace it. For any parts,filter or bags for this or any other unit visit www.stevessewandvac.com
Aug 12, 2008 | Miele Vacuums
Electrolux Oxygen3 model EL7001
If it is the top cover, the monitoring panel just pops off from the backside. You can use a thin knife or screwdriver and push on the locking clips, it then just hinges off of the front clips. After that is off you can see the two screws and after the top cover hinges off the actual door to the vac bags is attached to that cover it too hinges off.
Hope this helps
Mar 08, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Jan 14, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Dyson DC33 Animal Bagless Upright Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
