Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 does not start
Everything is fine one day and the next day it won't turn on. However, the power button has blinking light. Sometimes if I plug is off for some time and then try, it works. This time, I plugged it off yesterday and kept it off for almost 24 hours, yet it didn't start.
Please help.
Thanks
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    When you say the Power button is blinking, is it blinking Green or Amber?
    Awaiting a reply via the comment button.
  • 157 Answers
Could be a number of things, First take the ram out and then put it back in and see if that helps. next I would unplug any devices not required to start the computer.
You need to be familiar with the inside of the computer to do this.
Most likely suspect however is the power supply.
Posted on Jun 19, 2009
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 Diagnostic Lights 31 BLINKING 3,4 SOLID
Hi you've either got the wires on the wrong connectors or they need to be turned around, i.e. red needs to be where black is. Hope this helps
Mar 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blinking yellow power led
check at the back of the tower you would find 4 LEDs(small lights) labeled ABCD in a row or you might have 1234 on the front panel. note the status of these LEDs when the problem occurs and check for the solution accordingly on the support.dell. website.
would also suggest to disconnect all the devices (keyboard mouse printers etc.)next time the problem occurs and then try to start the computer
May 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
353 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
