Question about Samsung Washing Machines
Samsung wa80k6 water not draining during spin
localwonder
  • 6784 Answers
SOURCE: washing machine won't drain water
Hi there, here are some solutions to combat this issue. Check for restricted drain system. i would trace the hoses and check to see if they have became twisted or clogged. Next, in cold climates the main drain hose can become frozen. this can be a issue as well.you could also have a control board sensor that checks the water rate. this sensor could be out as well.i would also check the control board connections at cn10 (6pin). this is the wire running from the board to the pump. this could be lose or disconnected. lastly, check the tube to pump tube. this could also be twisted or clogged. hope that helps and, thx for using fix ya.
Posted on Feb 13, 2009
jsrock516
  • 5911 Answers
SOURCE: water doesnt completely drain or spin during last cycle
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. This is the most common cause of this symptom on Whirlpool manufactured washers. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 27, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
kevin_getz
  • 1031 Answers
SOURCE: The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Posted on Dec 22, 2009
jan mczeal
  • 632 Answers
SOURCE: water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Posted on Jan 23, 2010
We just put a drain pump on a samsung top loader and since then it drains and spins but the clothes are stuck to the sides but are still wet.
When a washer is doing it's final spin, there is a short period when water is sprayed into the tub.
It sounds like your washer is spraying water into the tub, during its final spin, for a much longer time than usual
Aug 14, 2016 | Samsung 4.8 Cu. Ft. HighEfficiency TopLoad...
Water is blocked inside the machine
The warning buzzer should have sounded after 15 minutes with a warning code of "5E" on the display, if the machine has recognized the fault. Check the drain hose height reaches 90-100 cm as stated in the manual. Set the machine to spin only cycle and minimum water level:-
Press the FUNCTION button four times.
Press the START/HOLD button once.
Spin drying goes on for 11 minutes.
(When the FUNCTION button is pressed during spinning,
the spin time can be changed to from 1 to 7 minutes.)
If this doesn't work try repeating spin and reducing the height of the drain pipe gradually 10cm at a time.
Operation manual available here: http://www.nodevice.com/download/user_manual/samsung+wa80b2s.html
Good Luck.
Jun 08, 2014 | Samsung Washing Machines
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Dec 22, 2009 | Washing Machines
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
