Question about Maytag Washing Machines
Maytag 2000 drains all water and spins but spins slow
Maytag front load washer spins water out but doesnt spin as fast as it should , no codes showing?
    Problem Solver:
  • 18 Answers
Two things, first one is could be the r-11 resister on main board burned or a tub bearing . check the main board inside touch panel. on it is a resister that tells computer door lock is or is not latched door lock light may be lit but computer indicates not and will not advance to max spin. if resister is burned and board is replaced be sure that you replace the wax motor door lock motor as well. if you don't replace locking motor you risk burning out new board again. tub bearing is easy to find out. just lift basket at top with finger and feel for vertical movement of basket alone,"slop" or "movement up/down. if so then replace the rear tub shell and spinner for basket . hope this helps.
Posted on Apr 18, 2014
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
It does not spin out the water and the items in the washer are drenched with water. It does not spin fast at all. Only two years old.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 09, 2011 | Maytag Washing Machines
I have a maytag fav6800aww and it doesnt want to drain the water and it makes a loud noise coming from the pump. i already replaced the pump and it still has the same symptoms. what should i do to fix this...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Will not spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Maytag LAT3600A Top Load Washer
Maytag Performa agitates, but wont spin corectly.
heatman101
Jun 07, 2010 | Washing Machines
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
