Question about Dirt Devil Vacuums
Dirt Devil Bagless Breeze Cyclonic
I was vacuuming with my new Dirt Devil for the 3rd time, when all of a sudden, it just stops, it was if I had unplugged it, or clicked it off, the area that I have used it on the other 2 times is only about a 10x14 the same area I was vacuuming today. can someone help me figure out what's wrong with it thank you, Laura
  • Dirt Devil Master
  • 1,464 Answers
Filters can clog quickly or you may have a clog somewhere which will reduce airflow causing the motor to overheat and shut off. It will come back on after it cools down. If that is the problem you may need to clean or replace the filters. If that does not solve it I would take it to a Royal warranty repair shop.
Posted on Apr 19, 2014
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: dirt devil vision bagless vacuum- not working
You didn't say how it runs before going off. You could have a clog in the hose or dirt inlet by the brush roll. There is a thermo protector on one leg of the wire going to the motor, if it is bad, it could be sensing the motor getting hot and casuing a shut down. Could be just a bad connection somewhere and vibrations casuing it to loose contact. Could also be a problem with the motor.
Posted on Apr 15, 2008
My new dirt devil vacuum cleaner. It stopped running and won't turn back on.
If it stopped from overheating because of a clog or restriction somewhere it will start back up after it cools down. If that doesn't take care of it take it to a warranty center.
Oct 22, 2017 | Dirt Devil Vacuums
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
My vaccuum just shut off on me. Ive never had a problem til now. It made no weird noise or smell just stopped working. What can i do?
check the power cord for a broken wire
check power point
check switch
take it to an appliance repair centre for a diagnosis.
Jun 14, 2015 | Dirt Devil Breeze Cyclonic Bagless Upright...
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
Why vaccum not emptying
Hi! If no dirt is entering into the dirt cup it could be that you have a clog in your hose. Detach the hose from both ends and use a broom stick or something similar to carefully loosen and remove any clogs in the hose. Hope this helps! If not you can always reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil. Thanks!
Aug 29, 2014 | Dirt Devil Breeze Cyclonic Bagless Upright...
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Bush roller squelling on dirt devil 130005 upright bagless cyclonic vacum
My dirt devil has 3 screws underneath- these are the same ones you use to change the belt--sounds like something is caught in roller-- mone was full of hair!
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Vacuums Logo
108 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
