SOURCE: Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used:
HANDLE, DOOR (WHT)
Level of difficulty:
Difficult
Time to do repair:
30 - 60 mins
SOURCE: refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
