Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Belt issue Hoover u5780.Took vacum apart,now brush bar spins,even if lever pressd 4 bare floor Replcd belt, brush stil spins. Position of belt off?
  • Tracy
    Tracy Apr 18, 2014
    I've got the opposite problem right now! I replaced both belts and now the brush bar won't spin!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 15 Answers
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
Posted on May 05, 2014
Kaoeria
  • 36 Answers
SOURCE: Spin bruches don't touch floor.
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
SOURCE: hoover steamvac brushes don't spin
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Posted on Feb 20, 2009
  • 97 Answers
SOURCE: i have a hoover steam vac f5899-100
if after you cleaned the brushes and still doesn't work. it will have to be the turbine assembly that the brushes fit into.
Posted on Jul 20, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
Brush not spinning on my montiss turbo 850 vacuum. Hoover suction ok. Have took apart and deluded and still not working
Check the belt. If the beater bar will spin with the belt loose but not spin under power, the belt may be slipping.
Jan 28, 2015 | Hoover Vacuums
I ran the vacuum over throw rugs and the brush roller just stopped. I can't get the roller to work now... it won't even spin and the "brush" feature is in the ON position.
You've got a broken belt. Most Hoover Vacuums have a spare belt attached to the vacuum itself. Replacement is fairly easy and usually won't require tools. To replace your belt:
  1. Unplug the vacuum
  2. Locate clips on bottom of vacuum-Hoover uses clips that can be opened by hand.
  3. Lift up the plate that encloses the rollers
  4. Remove broken belt
  5. Remove roller from it's compartment
  6. Install replacement belt (hooking it around the motor and roller, using the roller for leverage to stretch out the belt until you have the roller in it's compartment.
  7. Replace cover
  8. Put clips back in place.
Mar 21, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Agitator bar makes a rattling sound when engaged.
Unfortunately, you may need a new brush roll.
Read this review and see what you think.
click here
May 04, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
95 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
