Question about Ford Vehicle Parts & Accessories
WHAT WILL MAKE THE CATALYTIC CONVERTER TURN CHERRY RED WHEN RUNNING VEHICLE I JUST ADDED A ALL NEW EXHAUST AND PLUGS ANY IDEAS ?
Why does exhaust get so hot when started
  • 21 Answers
I n the old days I would have said the timing was out ,but check the car for fault codes.
Posted on Apr 18, 2014
Missing then no power . Stopped exhaust glowing red .now want start but turns over
Your catalytic converter is bad ! misfiring cylinders sends raw fuel down exhaust to catalytic converter were it burns an melts the insides causing it to plug . Suggest you take your vehicle to repair shop ! A new Catalytic converter can cost up to $700.00 or more . Some states , New York , California have to have Carb. certified cats .
Apr 04, 2016 | Cars & Trucks
My muffler for toyota get hot and red
Are you sure its the muffler....or is it the catalytic converter? It is not normal for wither to get cherry red - this usually means that you have raw fuel being burned in the exhaust stream. This is usually due to a burnt exhaust valve.
Jan 18, 2015 | Toyota Cars & Trucks
From a cold start motor runs normal up to about 5 minutes.then runs rough likes it only running on 3 cylinders and then dies and wont start. no engine light come on.
YOU HAVE A HONEST EXHAUST GUY, BUT YOU MIGHT WANT A MORE EXPERENCED MECHANIC. THAT CAN CHECK THE PROBLEM OUT CORRECTLY
Dec 20, 2014 | Cars & Trucks
Toyota T100 loses power when driving. New spark plugs, wires, fuel and oil filter
new catalytic converter may be faulty restricting exhaust causing loss of power.
Oct 14, 2014 | 1997 Toyota T100
How to know when catalytic converter goes out on a 2001 jeep grand cherokee
Your "Check Engine" light will come on, the exhaust should smell worse than normal, the engine MAY refuse to run well at higher road speeds (if the catalytic plugs the exhaust pipe), and most importantly... if you crawl under the vehicle with it fully warmed up and bring your hand near the catalytic converter, it'll be hotter than the rest of the exhaust system if it's still functioning. If it's not functioning any more, it'll be the same temperature as the rest of the exhaust system.
A good catalytic converter may be hot enough to glow dull red after it's warmed up. That's why the manufacturer always wraps heat shields around them, to keep that heat away from the paint under your vehicle and keep the excess heat from entering the passenger compartment.
Aug 01, 2014 | Cars & Trucks
Just bought a 1997 corvette been sitting a while charged up battery would not stay running was missing only ran when i kept on fethering pedal the noticed exhaust pipe got cherry red
Check to see if the exhaust is exiting the rear tailpipe. Could be a plugged up catalytic converter. Or some sort of obstruction in the exhaust system....
Mar 30, 2014 | 1997 Chevrolet Corvette
Catalytic converter turns red hot on my 2002 ford escape
The cherry red is probably due to raw gasoline being burned in the converter. Since the engine isn't running right (and I'm surprised you didn't say the Check Engine light was on), there seems to be some kind of valve timing issue or perhaps a burnt valve that is causing at least one cylinder to not fire and thus expel the fuel/air mixture into the exhaust stream. This can be confirmed with a compression check of the cylinders. If they are all low, then there is a problem with valve timing, possible a jumped belt/chain. If only one cylinder is low, then a burnt or broken valve is more likely.
Jan 15, 2014 | Ford Cars & Trucks
Catalytic converter glowing cherry red
time to get a new converter been down that road before
Sep 18, 2012 | 2004 Ford Escape
New catalytic converter gets red hot
clogged , check the rest of your exhaust after cat to see if it gets hot
you can buy a no contact thermometer for less than $55.00
but the shop that installed the cat should have that
good luck
Jun 03, 2009 | 1989 Isuzu Trooper
Not running right
TRY CHANGING THE DISTRIBUTOR CAP TOO
Jan 10, 2009 | 2001 Kia Sportage
Vehicle Parts & Accessories Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
