Question about Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15 Gauge Angled Finish Nailer
Air blows out through the exhaust when air hose is attached
Hi, when I attach the air hose full air pressure blows out through the exhaust. What may be causing this ?
    President:
  • Hitachi Master
  • 1,383 Answers
Most likely worn headvalve Part# 882927 not expensive and available thru www.toolreplacementparts.com. However you could try cleaning and lubing the headvalve. Sometimes debris will enter the gun thru the air hose and lodge in the head. Use white grease or silicone paste. Good luck.
Posted on Apr 21, 2014
How to flush a gmc heater core
Dear Tim
Disconnect the heater hoses from the engine block.
Using some steel or plastic pipe of the right diameter to fit inside the hoses.
Clamp the pipes inside the hoses, and attach a garden hose or a compressed air hose to the pipe to blow the heater core clean. Remember, the normal pressure that the core is designed for is about 15 # per square inch, so either normal household water pressure or an air compressor can blow the core to pieces, so be REALLY gentle whilst blowing it out.
God bless your efforts.
Dec 13, 2016 | GMC Cars & Trucks
Air want blow out dash vent only the defrost vent
You should be able to get enough air pressure from an air compressor to do this. If you need something to get further in then you can use an attachment to give you more length. Attaching a piece of rubber hose to the end of your attachment would be a cheaper way to go. You can pick that up in any length at a hardware store.
Aug 15, 2014 | Cars & Trucks
I have a hose with a filter attached to it on the right side of the bike and every time i start the bike oil flows out of it?
check the oil level and make sure its not over full. the hose with the mini filter is a crankcase breather, if there is too much oil, it could cause oil to flow out the breather. It is possible that the rings are worn or broken causing blow by or extra crank case pressure. The hard shifting is usually caused by a dragging clutch or the clutch being out of adjustment.
Mar 14, 2012 | 1989 Yamaha FZR 600
Washers keeps filling and overflows does not agitate
Your washer has a hose that goes from an air dome on the side of the tub to a pressure switch in the console. As water fills the tub air pressure increases to the up the hose to the switch and that is how the switch regulates the amount of water in the tub. More than likely the hose has either come off the switch in the console or the switch has failed. You will need to gain access into the console and check the look for a clear rubber hose that attaches to the back of the water level switch and make sure it is still attached. If it is not reattach it and try it again. Sometimes an out of balance load will cause it to come off. If it is still attached you can remove the hose from the switch and blow through it to make sure it is clear from obstructions. If the hose is clear and detached from the switch you will need to replace the pressure switch. Thanks and hope this helps.
Sep 12, 2011 | Roper RAS8445KQ Top Load Washer
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
We tried adding freon to our 98 Montero AC unit but when we attempt to it says the it is at full pressure and will not let us add any but it is only blowing hot air with the ac on, so we do not think it...
Hi, if you have full pressure (40-50 PSI on low pressure side with engine running A/C set to maximum and blowing) you have enough pressure, but there is air in the system which degrades the refrigerant leading to no cold air. To remedy this, you must completely discarge the system and refil with new R134a which has the compressor/system oil added to it.
To discharge the system, shut off motor, attach your filler hose to low pressure valve and allow system to drain. (squeeze handle if you have that type filler hose) Allow it to drain until no sound of escaping air is present. Be careful not to have the end of hose facing you or others, wear gloves and have some shop rags laid down, pointing nozzle toward rags, that stuff can damage paint and skin and may be cold when escaping. After system has completely drained, start the refil process with engine running, A/C on maximum, blower on full. After about 1/2 of the first can of R134a or 1 full can, your compressor should kick on. Continue refilling with 3-4 cans total (about 3 LBS total) until you have a reading of 45 or so PSI. After each can, allow refrigerent to cycle through the system about 3 minutes to obtain an accuret pressure reading. Pressure is relavent to outside temperature also, optimumly the ambient air temp. outside vehicle should be between 72 and 80 degrees F. for proper reading. That should get you blowing cold air again!
Please rate this answer! Thanks, Mike
Jun 14, 2011 | Mitsubishi Montero Sport Cars & Trucks
Seems to over fill the load with water and goes to ol at end of cycle
Hi.
The water level is determined by a pressure switch. The pressure switch is located near to the control module and attached to thin a rubber hose that goes inside the tub. Check the hose attached to the pressure switch for blockage. Blow into the hose and see if the pressure switch is clicking.
If replacing the pressure switch does not help, then problem is either a stuck inlet valve or a defective electronic control module.
A defective pressure switch is the most common fault that will cause this problem.
You can get parts and diagrams for this washer entering the full model number here.
Regards.
Ginko.
Jan 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Hitachi EC12 Portable Electric 2hp Air Compressor. It builds air pressure fine and shuts off normial. But if I attach a blow nozzle or another attachment to the hose and try and use it, the...
This is a stab in the dark.....but have you emptied the condensation out of the tank? It may reach max pressure....but have little air compressed inside the tanks. Just a guess.
Dec 13, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Furnace will not run indicator shows 3 red flashes with the led. According to the book this represents a pressure switch open with inducer on error. Any help appreciated
There is a pressure switch on the inducer motor with a rubber hose attached to it. Make sure that this hose is attached and is not cut or leaking, it's much like a vacuum hose on a car. Also make sure that the inducer motor is operating normally, nothing blocking the flow of air through the flue.
Oct 15, 2008 | Frigidaire Heating & Cooling
Overflowing
This is a symptom of a pressure switch problem. Open the console and double check the pressure switch (located behind the water level knob) and make sure the rubber hose is still attached. In many case, this hose vibrates loose and comes off the pressure switch. Without the hose attached, the pressure switch never senses the change in pressure from the wash tub required for it to be shut off. The end result: your washer continually fills without shutting off. If it is a simple hose problem, you can prevent this from reoccurring by placing a small zip tie around the air hose at the point where it attaches to the pressure switch. Do not over-tighten as you may damage the switch fitting. Just make it snug.
If the air hose is still attached, and the electrical connections are still attached, replace the pressure switch. I could not find a part number with the model number you listed this under. Please double check you model number again and post back, so I can assist you finding the correct part (if needed). I hope this helps you. Let me know if you have further questions.
Jun 11, 2008 | GE WHRE5260E Top Load Washer
Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15 Gauge Angled Finish Nailer Logo
120 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Joe Garcia
Joe Garcia
bwbconstruct
Level 1 Expert
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
